Question about Belkin Wireless Desktop 130
How do install the wireless desktop - Belkin Wireless Desktop 130
I cant find a wireless option on my inspiron 537
does your pc have a wireless card installed in it? otherwise you will not show any wireless connections or options. older desktops did not have wireless cards, like modems, installed originally. if you install one after-market on your motherboard, you will need to load drivers too. then restart and check for windows updates.
Oct 21, 2013 | Dell Inspiron 537 ST PC Desktop
How to turn on wireless switch on a desktop
I've never seen a 'switch' on a desktop to turn-on wireless, like there are on Laptops/Notebooks.
Usually it is either a device that is install in a slot in the PC, or it is a USB plug-in adapter. There ARE some motherboards with built-in Wireless ability, those can be turned-On/Off in the BIOS.
You would have to have a Wireless Router/Wireless Access Point in place already, it would need to be setup and security enabled.
Then it would be a matter of installing the driver for the device....WHEN you do that depends on the type of adapter you have:
add-on slot adapter -- Install adapter, then driver software
USB -- install driver software, DO NOT plug-in adapter until directed to do so, or the driver installation finishes.
Tallon41
Sep 18, 2012 | E-Machines eMachines Desktop PC
How can i get my emachine desktop to go wireless?
First you need a wireless router. If your router downstairs is wireless then the easiest thing to do is buy a USB wireless adapter for your desktop. All you need to install that USB wireless adapter is to plug it into one of your USB ports and install the driver for it. Depending on your operating system and model of your USB adapter, the operating system may even automatically install the driver for you.
May 19, 2012 | Microsoft Computers & Internet
Can the sr1123 wm desktop go wireless...what hardware do i need
@jlingenfelte
Since this desktop PC doesn't have a built-in wireless card installed, you have two options to get this computer connected wirelessly.
Option 1:
Install a PCI Wireless Adapter (example here)
Option 2:
Install a USB Wireless Adapter (example here)
Either options will work fine. Good luck.
Sep 07, 2011 | HP Compaq Presario SR1123WM (PC184A) PC...
Can get wireless on my dell gx270
Most desktop computers do not have a wireless card installed.
You need to install a wireless card in the expansion slot and install the wireless driver, then configure this wireless card with your router's wireless settings so it can connect to the wireless router.
Aug 11, 2011 | Dell OptiPlex GX270 PC Desktop
Can't get my dell to connect to wireless (desktop)
The 530 does not have a wireless network card. If you installed a wireless (wifi) card or USB adapter it usually comes with an installation CD which will guide you through the install process.
Feb 20, 2011 | Dell Inspiron 530 Desktop Computer
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Need to download a wireless adapter for my Gateway 830gm desktop
Are you sure there is no wireless device in the machine? Picking up a wireless connection in a desktop without a wireless device is a bit of an impossibility. Do you have a cellular device connected to the computer? Some of the cell wireless cards (Sprint for example) double as wireless cards for wifi hotspots. Many cell phones can be treated as wireless modems on your computer. Take another look and post back.
Jan 17, 2009 | Gateway 830GM PC Desktop
E-machine Lynksys wireless card
Yes it should but you need to have a wireless rougher also to pick up the modem
Dec 16, 2008 | E-Machines eMachines Desktop PC
Wireless Desktop Computer
YOu need to install a wireless LAN card in your desktop in order to connect your Desktop with wireless Router.
There are lots of companies manufacturing W-LAN cards..
one of the most recommended is MSI.
USB wirelless Network receivers are also in market now . they are easy to install; like you don't need to open your desktop physically.
Let me know if it helps.
best regards,
Dec 03, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Belkin Wireless Desktop 130 Logo
22 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
