Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
What is the fluid inside the color tubes i was trying to fix the red on my tv when i noticed that there was an air bubble inside it and was told to change the fluid but i dont know what the fluid is and where to buy it
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 11 Answers
That is cooling oil... MCM electronics , or electronix.com , Union electronics.... remove old oil. i always replace the gaskets , tube must be removed, sat up , a black and decker work bench will work with the table open and level. good luck
Posted on Sep 08, 2010
Play and the color chang and go out hiw do I fix it
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 20, 2013 | Philips Televison & Video
My tv has a red tint to it not sure what to do?
BEFORE
AFTER
Feb 17, 2013 | Philips Televison & Video
Blue color is getting weak
  • Screen looks 3D
BEFORE
AFTER
Feb 03, 2013 | Philips 55PP9401 55" Rear Projection...
SPIDER WEBS in my screen
Check the mirror and lenses inside the tv for any debris...if thats not it the crt fluid is likely gunked up....see the doc below...
  • Screen looks 3D
BEFORE
AFTER
Jan 28, 2013 | Philips 55PW9363 55" Rear Projection...
Picuture is showing double/triple with blue and red colors outlining characters on the screen.
  • Screen looks 3D
BEFORE
AFTER
Feb 21, 2011 | Sony KP-48S75 48" Rear Projection...
Lost focus.looks 3d. red double. cant focus on red convergence.
This is a very common failure on Projection TV2_bing.gif sets.
  • Screen looks 3D
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
47a7bc4.pngSOLUTION
This is a a fairly easy DIY job if you know what you are doing or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
Jan 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a glow or a shadow around everything I watch...I tried the converse blue but i dont know if i did it right bc it didnt work...how can I fix that?
CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 17, 2009 | Philips 50P8341 50" Rear Projection...
55 inch with blue ghost like glow on white or blue colors
Inside of your TV their is a fluid that keeps the tubes cool. Over the years this fluid will turn cloudy and cuase the screen to look dull, bright white, have halos, etc. You can get the fluid over the internet from various sources or your can get a complete kit including repair instructions from www.TvRepairKits.com.
May 08, 2009 | Philips 55PW9363 55" Rear Projection...
I think I have the same TV darker color not as sharp
the fluids do need to be changed occasionally.hes right about that.if you allow him to do it he will clean everything associated with the tubes
Dec 29, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 55p8342 chassis ptv916
To get a new remote call a local TV service company or you can order directly from the manufacture. The cloudiness of your colors are caused by possibility of two things or both: 1) The mirror and lenses inside your TV need cleaning (use window cleaner & soft cloth) spray liquid onto cloth, 2) The fluid in picture tubes need to replaced. To replace fluid (ethylene glycol) take tubes out of unit, drain fluid, clean fluid chamber, add new fluid. How you can tell if fluid is cloudy? Take off screen assembly look into each light (red, green, blue) the picture should be clear. The red tube, light, is normally okay, so use as referance.
Feb 16, 2008 | Philips 50P8341 50" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
