Question about Samsung HC-P4363W 43 in. TV/DVD Combo
DVD player isn't loading and playing properly
The DVD player doesn't load properly, keeps saying no disc when disc is in; I hav to take it out and put in several times before it will play, this often takes 10-12 minutes
  • willowp May 13, 2008
    Is the lens where you place the DVD? Sorry I'm so dumb!
  • 4,234 Answers
Since it will play eventualy, I'd suspect a dirty lens. Open up the unit and carefully clean the lens using a cotton swab and alcohol. Also, try a music CD. If the CD works flawlessly but DVDs still fail occasssionally, the optics are starting to fail and will need to be replaced.
Dan
Posted on May 13, 2008
  • ABRsvcs May 14, 2008
    1) There are no dumb questions. Better to ask than break something.
    2) Yes you need to open up the unit. You may be able to get to the optics with the drawer open. The optics will be where the CD sits in the play position. You should see a small clear lens. If you can reach it with a cotton swab, dampen the swab with alcohol and carefully clean the surface of the lens.
    Report back how you make out.
    Dan
DVD will not load or play. Just keeps saying loading over and over
This probably means that your DVD player has a dirty lens or a tracking problem or both. If the DVD player has a tray, you can try putting an optical disc lens cleaner into the unit. (Slot-loading DVD units may not properly accept or eject the disc. So don't try a cleaning disc in that type of unit.)
Since most DVD players are cheap, it's usually better to replace the unit if the tracking is bad. Similarly, if a lens cleaner does not work, replace the unit. If the player is under warranty, contact the manufacturer.
I hope this helps.
Sep 29, 2013 | Toshiba Se-r0047 Remote Control
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
When I put in a disc it says it's loading; however, it keeps showing "no disc".
when I put in a disc it says it's loading, however it keeps showing "no disc"
Oct 27, 2009 | Mintek MDP-1760 Portable DVD Player
Player justs keeps saying "bad disc" !!
clean your dvd lens with dvd disc cleaner.
May 30, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd keeps saying loading but won't play
Sounds very much like you have a either a dirty laser, or a laser unit failure. Put a cleaning disc through the machine, and see if it improves. If not, then you need to either have a new laser fitted, or a new machine.
Mar 14, 2009 | Samsung DVD-V3500 DVD Player/VCR
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Samsung dvd home cinema system ht-ds110 not playing dvds
My initial IDM-1731 tells me no disc every time i try to play dvd cd please help me
Jan 06, 2008 | Televison & Video
Sd370e dvd player
the dvd player does not actually play hd dvds just upscales normal ones
Nov 29, 2007 | Toshiba SD370E DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Says Bad Disk
I WENT BACK LATER, ROTATED THE DISC ABOUT HALF A TURN AND IT LOADED. TOOK IT OUT PUT ANOTHER IN AND IT LOADED JUST FINE ALSO. MAYBE IT WILL KEEP WORKING OK.
Oct 27, 2007 | GPX D1816 DVD Player
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
143 people viewed this question
Henry  Thomas
Henry Thomas
