Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door wont close - acts like there is an object in the way. If is detach the door from the sliding unit, the door closes easily. If I try running the slider down without the door attached, it stops very shortly after activation. If I close the dorr and activate the slider it completes it path. The door has increasingly been balky. At first if I shadowed the receiving unit the door would close but now nothing helps and I must manually lower the door. Suspect that the sensor has deteriorated over the 4 years it has been installed. Suggestions? TIA!
    President:
  • 3,197 Answers
It sounds like the sun may be shining on and causing problems with the door sensors. Try using the cardboard tube from a roll of toilet tissue on the receiving sensor.
Posted on Sep 07, 2010
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
I have a LiftMaster garage door opener. It has started to act up a bit, and I can't seem to locate the problem. It opens just fine, but when we try to close it, with either the remote or the wall control,...
If the opener feels any resistance it will act like this.Make sure that the rollers on the door to frame are oiled well and turn easily, move in and out easily as well, you can also turn the screw to increase the resistance stop pressure.Oil the rollers well
Jan 22, 2011 | liftmaster Chamberlain Garage Door Opener...
My garage door opener opens fine from the wall unit and the remote, however closing is a problem, when closing the door from the wall unit I have to press and hold until the door is fully closed, if I...
You have a door sensor problem. The IR sensors found at the bottom of the door rails will need some attention.
Both have an LED visible. Is one on or none? If none are on, check the wiring. Older models had a plug in the rear of the sensor that corroded due to moisture, causing intermittent or no operation.
If 1 is on, check to be sure that they are aligned with each other. If they are crooked, the door will not close without holding the wall button (as you described). They are easily knocked out of alignment.
Check for cobwebs and debris blocking the sensors.
Replacement sensors are around $50 and are easily installed with just wire cutters and pliers. Remember to unplug the unit before replacing the sensors.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont stay closed
have you gotten the instalation instructions out and go through the set up procedure
and why did you rewire the sensors ?
the settings are critical but not rocket science of course then if the problem still persists and you can confirm the sensors are working correctly
then you may have to replace the logic board on the unit
try doing a mock reinstall and adjust and see if the problem isnt something simple
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1265 garage door opener, tried to
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Power shuts down when I try to close or open
Your motor may be working too hard anad ripping the reset button on the garage door,
Try increasing the power on the unit ( should be some type of dial.) or the door may be jamming up somewhere, Try disconnecting the opener from the door and see if it goes up easily, the door might need service
Jun 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener (chain) motor runs in reverse. Trolley slides forward trying to close door, even though it is closed, instead of sliding toward motor to open door. Happened out of the blue - was
Loosen the chain enough that you can remove it from the sprocket. Run the opener until the sprocket turns counterclockwise and stops. With the door in the open position replace the chain. You will probably need to adjust your open and close limits per your owners manual.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Stripped gear
Try opening and closing your door by hand with the motor detached (detach it by pulling on the rope) It should open and close easily without a lot of effort. If it catches or is too heavy (possible broken spring) it will strip the gear. The door has to be working properly before you can attach an opener to it. If you lift your door up about waist high and let go of it . It should not go up or down but should stay in that position, This tells you that the springs are correctly adjusted
Feb 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
My sears garage door opener wont open or close the door
If you can get access to the back of your motor assembly on the ceiling and look where the wires are connected there should be a slide button that will have a list that will have you set the main unit to a position that will allow you to accept new remotes or reprogram for lost signal to existing remote. If all else fails there should be a phone number you can call listed on the unit and they can walk you through.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
259 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
