Question about Karcher 2500 PSI Pressure Washer
Won't build pressure
Unit worked fine the first year, but won't after sitting for a winter, what should be checked, supply pressure is ok.
  • Gary Alford
    Gary Alford Jul 29, 2012
    Check karchers web site on this, they have a video on the fix, its easy.
  • 313 Answers
The adjustable wand or pressur regulator may be clogged with rust inside. it's economical to replaced the wand assy.
Posted on May 25, 2008
Why will my 1998 chevrolet cheyenne not start unless primed after sitting overnight
by primed are you supplying a fuel source if so then the car is not getting fuel to burn. this indicates your fuel pump is bad and needs replacing and change the fuel filter also. the reason the pump won`t work sitting overnight is that the pump can`t build up enough pressure possibly because the fuel pressure is not being held, but after the first start up the system can maintain enough pressure to start through out the day. you can have the fuel pressure and volume checked with a gage when the problem occours to verify.
Aug 25, 2014 | Cars & Trucks
Pilot light on Intertherm MG 075A furnace will not stay lite on windy days. Worked fine for 20 years but has been a problem the last couple of winters. thermocoupler has been replaced a couple of ti
If this really is a thermocouple unit with a standing pilot, it must be pre 1978, I would suspect a crack in the exchanger first off as thats potentially lethal, not a joke, many heart attacks, headaches, fibromyalgia etc comes from undiagosed carbon monoxide exposures!
And many die from it sadly as it is 100% preventable, a detector would be advised even if you are ok there. A draft can be from the roof car ruting out or misssing? any dryer, Jennair, bath fan, water heater, stove top and many hvac systems create negative pressure in the home by exhausting air and not returning any or less than removed, as in a leaky supply duct leaking in the attic, the furnace pulls X cfm and returns Z
and fireplaces etc will backdraft. gas valves do get tired too.
Oct 31, 2012 | Dayton Gas Furnace Heater
Pressure washer won't pump
You didn't indicate what make or model pressure washer you have but if you didn't drain the water out of the unit and run conditioner through it before storing it, it's highly likely some of the check valves (there are six in most pressure washers) are frozen shut. If water was left in the pump and it got cold enough to get a hard freeze, it's possible the seals were damaged or even the case may have cracked. The only way to know what's damaged is to take the pump apart and go through it.
Aug 31, 2012 | Garden
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
Have a 2001 dodge stratus 2.7 95,000 miles going through second winter with no heat, flushed system, changed thermostat, checked for blockage, appears that there aren't any, hoses get hot, pressureized the...
I had the same problem with the same car...
I replaced the climate control center, (in the dash selector) and this solved the problem. I discovered this by first swapping mine out with a friends who had the same unit. This is an expensive part at the dealership but I now have heat. Hope this helps, I had a couple of long winters driving to work also!
Jan 30, 2011 | 2001 Dodge Stratus
Coleman model APW-120 May have frozen while stored over winter the unit is new but water was not completly removed before storage. Problem motor runs continuosly but there is no water pressure I have...
Whar has happened is that your unloader / bypass valve is sticking. This is due to minor corrosion and having water in the unit over the winter. Most of the time they will sanp out it if you do the following:
Add 3 - 4 oz of oil into the water supply connection and briefly and I mean very briefly switch on the unit then right back off. Add more oil to the water supply connection and then let it sit overnight.
Then next day turn the unit on briefly and let it sit another 30 minutes. After this you connect all hoses making sure to purge the air our of the supply hose BEFORE you connect the to the unit. Then once you turn the unit on rapidly trim cycle the wand trigger. Your goal here is to cause a water hammer of the unloader / bypass valve to get the spring and cupped seal to move in the housing. Pause briefly and see if pressure builds then fan the wand trigger again. This can take a few minutes to get it to work but the routine of pausing waiting momentarily and rapidly tripping the wand trigger is what should get the unit going again.
If this does not work you will have to take the unit apart dis-assemble the unloader / bypass vavle on the output side of the pump and remove the corrosion on the spring and the housing.
Once your done cleaning up the bypass unloader valve before you put it back in the housing place a liberal amount of Lubriplate #105 White Grease on the spring and inside the housing on the mating surfaces. (#105 white grease is available at any Auto Parts store. It is in a 3 - 5 oz plastic tube)
Re-assemble the unloader / bypass valve an it should work like a champ.
Thanks for choosing FixYa.
Sep 16, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
Husky pressure washer 80432. 1 year old. worked before the winter. no pressure this summer. honda engine runs fine. replaced the pump from the bottom of the engine down... still doesn't pressurize. ...
Check the inlet strainer where the water supply hose is attached,this is located just inside the coupling where you hook up the water hose.
Jul 30, 2010 | Garden
My 1 year old gas powered Husky model HU80432 starts and runs fine but gets no pressure from the wand. Water is running freely through all connections and hoses so there are no obstructions, just no...
Lime/calcium build up in the pump.
Pour a large amount of liquid TSP into the fresh water inlet and let it sit for two or three days, the longer the better.
This is how I fixed my no pressure problem.
Works great now
Jul 28, 2010 | Garden
No air ... compressor seems to be working OK ... a loose air connection?
That would be agood place to start. Try starting the unit and pressing your finger over the head and see if the pressure guage builds air you will only be able to hold it for a few seconds but just to see if its compressing air. If so its fine and check the connection where it is adding air to..
Sep 29, 2009 | Xantrex Technology XPower Powerpack 200...
I have a 3000 psi karcher pressure washer with honda engine, the problem is for a while the pressure would kick in and out, now only water hose pressure, the water supply is fine, what is the problem
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Sep 15, 2009 | Karcher G3025OH Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
287 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
