Question about Karcher K2.26 Electric Power Washer
My karcher washer has lost most of its pressure it doesn't clean the bricks like it used to
The lance hose that attaches to the pressure washer keeps coming off when the power to the machine is turned on, i've only used this product four times since new in January this year.
Posted on Sep 08, 2010
My karcher k7.85 has lost pressure and the motor runs constantly when switched on ,motor only used to run when trigger pulled in on lance ,there is no leaks. Can any one help please.
Sounds like the pump seals are bad. The manual says to only use these a few minutes at a time, most people try to clean the patio etc with them, run them too long, and burn out the pump seals - don't ask me how I know this.
Feb 17, 2014 | Karcher Garden
I HAVE A 2600 SIMONIZ GAS PRESSURE WASHER AND I HAVE LOST PRESSURE. CANT FIND THE PROBLEM.
Hi Trevor
You have one of two problems
1. Pressure relief valve is stuck and needs cleaning or replacement
2. Pistons that pressurize the water need new sealing rings or seals
Bud
Sep 28, 2013 | Karcher 2500 PSI Pressure Washer
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
May 03, 2010 | Karcher K 5.85 M Electric Pressure Washer
My karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Apr 25, 2009 | Karcher Garden
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
My Karcher HD 1050 DE has lost pressure, ive had new valves put on it but still has no go in it
could be allsorts. seals worn. ceramic pistons split, inlet manifold split( frost damage), unloader valve sticking, etc etc.
Put mains water pressure onto it and look for leaks, then run machine and see if it increases pressure, if not i would suspect unloader valve sticking.....
Not very familiar with the 1050 but i'm a service engineer for high press cleaning equipment...
Oct 12, 2008 | Karcher 2500 PSI Pressure Washer
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Karcher K2.26 Electric Power Washer Logo
367 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
