Question about Electrolux EOB6636X Ultrafan Electric Single Oven
EOB6630X ELECTROLUX ELECTRIC BUILT IN OVEN
I ALSO HAVE A PROBLEM WITH MY 3YR OLD LECLUX OVEN AND HAVE FOUND A SITE SELLING THE STAT FOR £18.00 . CAN YOU PLEASE ADVISE WHERE IS IT SITUATED IN THE OVEN AND IS IT A STRAIGHT FORWARD JOB IM QUITE HANDY WITH STUFF BUT I DONT WANT TO RISK SHOCKING THE WIFE OR KIDS HOPE YOU CAN HELP AS THE CALL OUT CHARGE FOR AN ENGINEER ALONE WOULD BE £80 SO IM WILLING TO HAVE AGO PLEASE HELP THANKS **** IN THE BORO ......
Overheat stat
Posted on Aug 11, 2008
    President:
  • 1,462 Answers
Which stat is it - overheat stat or temperature stat?
Posted on Jun 19, 2008
Light in the oven has gone off. Oven is still able to bake. What could be the issue.
http://homenol.blogspot.com/
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 07, 2016 | Electrolux 30" Built-In Single Electric...
The top oven is over-heating with no change in temp display. A red-hot heating element on the left side of the oven (facing it) shows through the floor of the oven.
Good Morning Eileen, thank you for your inquiry!
I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Electrolux 27" Built-In Double Electric...
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
Main oven switches itself off
sounds like cooling fan not working. check the fan and a limpet stat that switches it on. without the cooling fan the oven cabinet overheats and a safety cuts out the oven.safety stat could be faulty if no prob with other stuff.
Jul 20, 2010 | Electrolux EOU6330 Electric Double Oven
Eod6630 does not heat to temp changed element now does not reach temp on cooker
Try and locate the thermostat, check no wires have come off from there. Your old element may have been ok, you may have a faulty stat or a loose wire on one of the connections.
Dec 07, 2009 | Electrolux EOD6330 Ultrafan Electric...
Is it possible to purchase a different color door for the current model Electrolux 30" built-in single oven and install it? For example, if you have the model that is all black and you want a door that has...
I am unsure about the window part but I know of a site that sells covers for your ovens. While their site does not have the pictures of the oven doors available yet-- all their options are available for oven doors. They can help change your black existing oven door to white. I do not believe they can help you with the window---
Check them out www.applianceart.com
Nov 08, 2009 | Electrolux 30" Built-In Single Electric...
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Oven heats up then switches off
there is an overheat stat in the oven which turns it off if overheating. the causes are several. 1 - oven thermostat is faulty and oven is reachingf too high a temp. 2 - there is a second fan in the casing to keep the casing cool. 3 - this second fan is turned on by a fan start stat which may be faulty and is not starting the cooling fan 4 - the overheat stat itself is faulty. it is a bit difficult to narrow it down from afar. get back to me if you want
May 19, 2007 | Electrolux EOB6636X Ultrafan Electric...
Gas oven - fan constantly on
assume this is the casing fan. this is controlled by a fan stat which may be faulty. however, this fault should be covered under guarantee so call service agent
Apr 23, 2007 | Electrolux EOG6330 Gas Single Oven
Electrolux EOB6636X Ultrafan Electric Single Oven Logo
277 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
