Question about Sharp Office Equipment & Supplies
Sir, my copier is a sharp SF-2014. I recently had a new photocell ??(red cylinder tube) replaced. Everything worked well for a few months. Now the copies come out all black-with copied words appearing in the black in a background. A repair man via telephone told me its probably the toner collector not working properly and should be replaced. He also said the parts are not made any more .My questions are: Is there a repair manual which will show me how to replace the toner collector and where are parts available? Any help would be greatly appreciated. Thank, Jim Moran
  • 61 Answers
It could be the drum blade http://www.precisionroller.com/find/c9580.htm
It could also be the fuser. The fuser can ware down and have toner stick to it then transfer it to the next page,
http://www.precisionroller.com/find/f6320.htm
Posted on Sep 07, 2010
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Sep 29, 2009 | Sharp SF 2020 Copier
Sharp SF 2014 copier power problem
Check the power cable for power. If there is power at the end of the cable but the machine does no switch on,the problem might be with the power supply. If there is a fuse which is user accessible, check that. Otherwise its a technician job.
Jun 04, 2009 | Sharp AL 1631 Copier
Sharp sf 2014 copier problem
clean the paper feed rollers with soap and water damp cloth take paper tray out use flashlight to locate rollers also clean registration roller under the drum check and see if u have any broken gear teeth on your fusing assemby also if after cleaning it works i recommend u replace feed rollers
Jun 04, 2009 | Sharp Office Equipment & Supplies
SHARP SF-7320 doesn't start
Also adjust your front door which acts as a switch.
Apr 02, 2009 | Sharp SF 2020 Copier
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
I have been using sharp copier- table size(SF-2218). but recently a red image in form of a man is viewed which is stopping the copier from warming up.
Dear sir; The symble of red man, means need PM service, you need to replace DEVELOPER,
slide out developer unit and remove toner hopper(2 screw),Empty old developer,replace with full bag, reassemble, install back to the machine. power on, press "clear", "pause", "0", "pause" keys, then enter 25, press print, enter 2, press print,machine will run for 3 minutes, the "pause" key also call "interupty" key, when machine stop then press "clear" then enter 20 press "print" enter 01, press print, enter 0, then press clear key enter21 press print enter01 press print,enter 0, press print press clear twice to end the simulation.
If you not clear or need more help just email me, I always around, good luck!
DON'T FORGET GIVE ME A RATING
HAVE A HAPPY HOLIDAY !!!
Dec 22, 2008 | Office Equipment & Supplies
Sharp SF 2314 Copier
A U2, is normally caused by the toner cartridge not communicating with the main board.
Try removing and re installing the cartridge a few times.
If that doesn't work try replacing it with a new cartridge.
The memory may have dumped also. In that case a new memory or main board would be required.
Jan 17, 2008 | Sharp SF 2314 Copier
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
