Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold ice maker
The water spews out all over the inside of the freezer..I feel it must me something to do with the water line hose but can't see where it comes into the freezer itself. I paid $1600 for the fridge and had a new sensor for the ice maker put in several months ago at another $150 Any ideas???
simpson8970@yahoo.com
  • 868 Answers
The inlet tube is hitting the ice shield and missing the opening.Remove the ice maker just enough to align the tube into the hole in the shield.
Posted on May 29, 2008
My ice maker is not working on my gs5 sha side by side refrigerator freezer, it is spraying water everywhere inside the freezer, any help?
Make sure the water is coming from the ice maker by using additional light to spot the source of the leak then you possibly have a defective water fill valve leaking water slowly and causing water to freeze where water exits the tube into the ice maker. Once there is ice there and the ice maker calls for water the water either spews all over everything or is blocked from filling the ice maker cube slots altogether. The only repair is to replace your=> Whirlpool Refrigerator Water Inlet Valve W10408179 I'm here on Fixya if you have questions
Contact Me Here
Nov 20, 2015 | Refrigerators
Why is ice maker spraying water everywhere inside the freezer?
Make sure the water is coming from the ice maker by using additional light to spot the source of the leak then you possibly have a defective water fill valve leaking water slowly and causing water to freeze where water exits the tube into the ice maker. Once there is ice there and the ice maker calls for water the water either spews all over everything or is blocked from filling the ice maker cube slots altogether. The only repair is to replace your=> Whirlpool Refrigerator Water Inlet Valve W10408179 I'm here on Fixya if you have questions Appliance 911 Sea Breeze Contact Me Here
My whirlpool gold ice dispenser leaks water and creates icicles inside, what could this be?
bad water valve or the ice maker is cracked,if the valve doesn't work correctly it can let to much water into the ice maker causing it to overflow or the ice maker has a crack in it and the water leaks out.
Jan 23, 2013 | Whirlpool GS6NBEXR Side by Side...
I have a Whirlpool Gold GD22DFXFW02 side by side fridge/freexer with ice maker and water dispenser. Besides the fact that the water dispenses very slowly, the ice maker has stopped making ice. It appears...
Sorry to read about your problem, I hope this helps you out.
yes no water to the unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Whirlpool Refrigerators
Stopped making ice
Hi reach up inside the tray where the ice is made and check to see if you feel any ice. If you feel ice the ice maker is bad. If you feel no ice and the tray is empty then your problem is either with the water line being blocked with ice or the inlet valve is bad. Pull the ice maker line out of the valve and blow into it, if you can blow air through the line then the valve is bad. If you can't blow air into the line then it's blocked with ice. Locate the ice blockage and thaw it with a hairdryer. Mike
May 14, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
turn on the ice maker theres must be a switch inside the freezer that turns on the solenoid valve
Mar 15, 2009 | Whirlpool Gold GB2SHDXPS Stainless Steel
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
203 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
