Question about Whirlpool Dryers
Gas dryer. flooded basement which means water damage to some parts .about 12 in of water. when I push the start button it clicks on but turns off right away if I hold button down it spins around for a minute than seems to overheat and turns off.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is ruined...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
Basement flooded and got approx 12 inches of water in bottom of dryer let sit for a week to dry before trying when pushing start button will come on but wont continue running unless you hold button in ...
Sorry to say but you will need to replace the motor. After water gets in you can rarely save the motor no matter how long you let it dry.There is an internal over load inside the motor that is cutting out after 30 seconds and once it cools for 15 or 20 minutes then it resets .Hope you found this information helpful and thank you for using Fix ya.
Jun 24, 2011 | Whirlpool Dryers
My drier was in a foot of water during a recent flood in my basement. Is it salvagable? If so, what would likely need to be replaced?
If this was a gas dryer; absolutely not. Electric can be more forgiving if it is allowed to dry out. Gas appliances become a safety issue because of damage to the gas valve.
Aug 10, 2010 | Maytag MDG2706A Gas Dryer
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
My basement flooded and now my gas water heater
Was the gas valve under water? If so it must be replaced. If not, and you're sure you are holding in the button for at least 30 seconds after the pilot is lit, the pilot will need to be removed disassembled and cleaned. Also, the thermocouple may or may not be bad, replace it anyway (for the cost @ Lowes etc just not worth it).
Sep 22, 2009 | Water Heaters
Flooded and not heating now
There is no pilot light. You probably got water into gas jets, also all electronics to ignitor need to be dryed. Also blow out all gas parts. If dryer was plugged in at time of flood you could have shorted one of the thermal switches behind back cover. Check all of this I wrote.
Aug 17, 2009 | Hotpoint NVL333GY Gas Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Dryer won't run.
First, there is an excellent chance you have some kind of flood damage insurance.  It may pay for part of the repair.  You did not tell us what is not working but I'll guess it is the motor.  On many models, there is a switch on the motor which will not allow the elements to heat unless the motor is powered and running.
Dec 19, 2008 | Kenmore 63942 Dryer
Whirpool Mod WGD5300SQ0
How much water did you have in the basement? Back in June we had flooding in the area, and the my recommendation to everyone has been to replace any appliance that was under any water.
If the motor was under water, wires or the gas valves, these components will corroded and could cause you future safety concerns.
Jul 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Won't start after flood
First I would remove motor and put it in an oven for a few hrs at min temperature like 200 degrees then I would remove motor centricical switch and push in the actuator tab a few times, then put it back in. Use a cheater cord plugged into pins 4&5 and see if the motor runs, it should.
Apr 17, 2007 | Kenmore 74972 Gas Dryer
Dryers Logo
164 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
