The canopy for the front seat. I can't get it to work correctly. I have it off the stroller right now & can't get the "pin" type things facing the same direction to put it back on the stroller.
I think lightweight stroller is the best stroller for a baby. It makes very useful for carrying children. I know this is the first choice of modern parents. There are also many other types of strollers that parents like. Such as umbrella stroller, jogging stroller etc.
For many parents, the Umbrella stroller is the second choice, and it is the first choice for many. It depends entirely on the parents' choice of parents. Many parents want to take their child along with jogging as well as they like jogging stroller. Therefore, it depends entirely on the parents.
I think lightweight stroller is perfect for everyone. This is because it has many qualities. It can be easily moved from one place to another and it is much easier to carry in the car. The best quality is its price is very low.
Fitting your Graco Snug Ride infant seat into a Graco stroller is usually easy to do -- the exact instructions just depend on which stroller you have. Typically, all you have to do is fold the stroller's canopy back, recline the seat (if it reclines), and snap the car seat in (backwards -- facing the rear of the stroller). You can hear it lock in place when it's in correctly. Your stroller's manual will have specific instructions, and if you don't have the manual you can find it online.
TO FOLD STROLLER • Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section. • The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame. CANOPY * The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23. SEATBACK POSITIONING * The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically. http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
I just turned my seat and was confused by this too. I figured out that the plastic axis points have small buttons that you push in to remove the front half of the hood (be sure to unzip it). You then reverse the hood. you have to forcibly twist the plastic slats, that attach the hood to the axis points, around to the other side. It makes alot of clicking noices and is hard to turn but they do turn. Then you simply slide the slats back into place and zip the hood back together.
The canopy should just push onto the seat frame, they do need a bit of pushing though. its easier if you get the connector half on and then just push, will hear a popping sound. it took me a while to figure it out on mine and the instructions aren't the best.
