Question about Apple PowerBook G4 Mac Notebook
My g4 laptop goes to the blue screen and pinwheel, but wont boot uo, i reset the pram, no good
  • 863 Answers
Try cheap fix first of replacing hard drive and installing the OS. Then you gots to go for the spendy fix of new logic board.
Posted on Oct 06, 2010
Powerbook G4 12" 1.5 Aluminum will not boot. Apple logo and spinning wheel appear, sometimes eventually changing to a blue screen, sometimes remaining, until stopping with on/off switch. Aside from that,...
try booting with disk select option.
hold down option key and power up. Try resetting pram.
Look up key commands on apple support.
Try safe boot with holding down s key
etc....
Aug 28, 2013 | Apple OS Computers & Internet
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
Won't turn on
Open the memory and reseat it properly and reset the SMC and PRAM.and check.follow Apple website for Pram and SMC reset.
Apr 09, 2010 | Apple PowerBook G4 Mac Notebook
It boots up but no operating system or desk shows up
What happens when you boot up? Do you get the flashing ? Folder icon or does it freeze on the apple logo or something else? Try starting in safe mode (startup while holding 'Shift' key) and see what happens.
If problems persist -
Next force the internal hard drive to be the startup disk (reboot holding 'D')
Still having problems? Try resetting PRAM (reboot & press Cmd+Opt+P+R. Hold until you hear 2nd chime)... see what happens, if no success do the NVRAM (reboot & Cmd+Opt+N+V)
If all that fails let us know and we'll look at the next level of options
Oct 28, 2009 | Apple PowerBook G4 Mac Notebook
Startup switch on PB G4 17 not getting apple sound, takes numerous times to boot up. Using Tiger OS, upgraded to latest. Works fine, otherwise.
If a Mac is shut down while the volume is set to zero, the standard Apple startup chime will not sound, so it is impossible to say whether or not this symptom indicates a problem.
For a startup issue such as this, I would recommend zapping the PRAM and resetting Open Firmware.
To zap the PRAM, start with a powered-down machine, press the power button, then immediately hold down the four keys: command, option, P, R. After ten seconds or so, you should hear the optical drive reset, and then the startup chime (because the volume is reset to full by this procedure). Ten more seconds, another reset, another chime. After the second time you hear the chime, release the keys.
Shut the machine down again (if it doesn't start up successfully, hold the power button until the power goes off). Press the power button, then immediately hold down the four keys command, option, O, F. You will see some tech-speak on the screen, then it will wait for input. Enter the following three lines, pressing the "return" key at the end of each:
reset-nvram set-defaults reset-all
After the last line, your Mac will reboot itself. It should now boot much more reliably. If it doesn't, chances increase that you have a hardware problem. You may want to run the Apple Hardware Test from the DVDs that came with the PowerBook to check your memory and logic board. Failing this, you are in for a trip to the shop.
Oct 05, 2009 | Apple PowerBook G4 Mac Notebook
I cannot reset my PRAM on my iBook G4 14"/1.42 GHZ. I cannot get the power to stay on.
hello , if there has been any 3rd party memory installed remove it and attempt a PRAM reset again , as well you may try a PMU reset as it appears your issue is power related.
Sep 30, 2009 | Apple iBook G4 14-INCH Series M7701LL/A...
Imac g4 lcd black screen replaced pram battery
If you can find an older SVGA monitor, try hooking it up to the port on the back of your mac. If you get video then chances are the LCD display is shot.
Sep 01, 2009 | Apple iMac G4 Desktop
My mac powerbook g4 12'' wont chime or boot just comes on and screen changes colors every 2 seconds
Resetting PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 26, 2009 | Apple PowerBook G4 Mac Notebook
My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
Mar 18, 2009 | Apple iBook G4 Mac Notebook
Booting problem and blue screen
Try booting the MAC OS disk. If it boots correctly, it probably is the hard drive. Also, If it boots ok, try the repair utility on the cd.
Jul 28, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple PowerBook G4 Mac Notebook Logo
200 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
