Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
How to rewind the string on my toro 910 electric trimmer weeder
What size string does the 910 toro electric trimmer take
12' .050 trimmer line, like that shown at the link below
http://www.google.com/url?sa=t&source=productsearch&cd=1&ved=0CFkQgwgwAA&url=http%3A%2F%2Fwww.amazon.com%2FToro-88075-12-050-Trimmer-Line%2Fdp%2FB0000CBITQ&rct=j&q=910%20toro%20line&tbm=shop&ei=h2HNTd7aCunc0QGq_aDgDQ&usg=AFQjCNF826-xPNQy9XomBFrklrqkvIHGCQ&cad=rja&biw=1280&bih=630
May 13, 2011 | Toro& Electric String Trimmer
I dont know what string to use in my toro 8" battery trimmer
The thinner string works well in these machines and puts a lot less strain on them. I would suggest using a string of .065 range. The thicker (and more expensive) string used in the gas machines is too heavy for these lower powered electric units.
Sep 25, 2010 | Toro& Electric String Trimmer
String is wound incorrectly
Hello. Just pushing it back does not fix it. Cut off the excess and then you should be ok again. J.
May 24, 2010 | Toro& Electric String Trimmer
Toro& Electric String Trimmer: how do you take the bottom part off?...
Look for a couple small windows on the sides of the center knob that sticks out, push in on these, they are tabs that hold the center knob on, after that the string bobbin should slip right out.
May 17, 2010 | Toro& Electric String Trimmer
After going through at least 3 string-type lawn trimmers, I have yet to find one that can actually feed the string. I have used Black & Decker, and most recently, Toro 8" cordless, with the same...
This can and is a frustrating problem. Some things that help are to be sure to use the right size of trimmer line. Be careful when rewinding the reel to not twist and cross the lines. I realize we should not have to give this much attention to it, but until somebody "builds a better mousetrap", we only have so much to work with.
May 15, 2010 | Toro& Electric String Trimmer
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
113 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
