Replaced pc board on condensor model cmh1822 the condser fan runs but the compresser will not start
  • 382 Answers
Dear sir /madam
i think there is still connection problem please make sure all connection is connect well and all cable is connected and check compressor capacitor is good condition . and check all thermostat and temperature setting after that try you air con unit i hope it will work .
if it,s not work after use all this method if your air con not work please contact to your service technician for further action.
hope answer the question
please vote
thank you
Posted on Sep 06, 2010
Had a seized evap fan changed it with condser fan but won't run where the capacitor located and resistor? Lj390 m
no idea what you are talking about,make,model,year????????????????????????????????????????????????????????????????????????????
Apr 11, 2015 | Cars & Trucks
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Apr 20, 2012 | Samsung RS2630SH Side by Side Refrigerator
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Maytag modle #rsw24eo.refrigarator side will only get down to 60 deg.the freezer side working as designed.cleaned condensor and checked condensor blower motor.I think it is spining way,way to...
Your problem sounds like a defrost or control board. The condser fan sould run full speed when running. It will cost about 90-100 dollars. I hope this helps.
Aug 27, 2011 | Maytag MSD2656G Side by Side Refrigerator
Why is the exterior front in between the freezer and reridgerator door on my whirlpool gold getting very hot. the are both keeping everything at proper temp?
If this is less than 7-8 yrs. your condser fan motor is not running. half the it is the fan motor. the other half the board is bad. hope this helps
Aug 18, 2011 | Whirlpool Refrigerators
I have an intertherm furnace and the circuit board burnt up...replaced the board and the heat works fine....the a/c condensor comes on on cool but the fan will not come on
If you are talking about the fan motor on the condensor then I would check the start capacitor if it is an older model it should have a seperate capacitor in the elec. connection box for a/c condensor fan and compressor. Thank you.
Mar 07, 2011 | Heating & Cooling
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
Condensor fan not running
put your hand on the body and feel if it hot if hot change fan if cool problem
Nov 01, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
