Question about Canon PIXMA iP1800 InkJet Photo Printer
Md. Sohel Rana my canon iP1980 printer is blinking orange light 7 times then 1 green. what should i do? and here is a error msg An error occurred. An ink cartridge cannot be recognized.
SOURCE: we had just refilled the ink cartridge for canon ip1980
please reset manual first by pushing power button before plug in AC cord, then push resume button twice and release both, if still happen please reinstall driver
Posted on Mar 13, 2009
sugarfree
  • 31 Answers
SOURCE: my printer has a new ink cartridge but does not recognize the ink
The orange flashing light indicates that you need to replace the ink cartridge thus its is not recognizing the cartridge you bought.Epson recommends the use of genuine Epson ink cartridges. The use of non-genuine ink may cause damage that is not covered by Epson's warranties, and under certain circumstances, may cause erratic printer behavior. Epson cannot guarantee the quality or reliability of non-genuine ink. The ink cartridge status may not be displayed when non-genuine ink is used. Having said this, these are the correct part number for your printer.
C90
Black T0731/T0911
Cyan T0732/T0912
Magenta T0733/T0913
Yellow T0734/T0914
In replacing the cartridge make sure you also remove the yellow tape before inserting it. When you finished replacing the cartridge and closed the cover, it will charge the ink automatically in about 2 minutes. The only way to check the new cartridge you have inserted is to use the software in checking the ink levels. Accessing the software depends on the OS that you use.
Posted on Aug 05, 2009
57 varieties
  • 1653 Answers
SOURCE: Canon ip1980 after refill, status monitor still shows ink at low
This is a common problem with compatible cartridges where the chip on the cartridge is faulty, missing or is not making contact correctly with the printer cartridge connectors. The first thing to do is make sure that the plastic seal has been removed from the chip and that it is free of any residual adhesive etc. You can clean this with a cotton bud soaked in isopropyl alcohol or VCR tape head cleaner. DO NOT USE SURGICAL SPIRIT or any other cleanser as this will either leave a residue itself or damage the plastics and rubbers in the printer.
Once cleaned reinsert the cartridge and try again. If this is still unsuccessful the best solution is to return the cartridges to the vendor where you bought them and get another brand of cartridges or use genuine original cartridges. When you find a reliable manufacturer of cartridges, stay with them. Don’t forget to clean the print head and realign & recalibrate the printer at every cartridge change for optimum results. Also make sure that you use high quality paper for the best images results.
Posted on Oct 06, 2009
cene765
  • 787 Answers
SOURCE: Refilled ink cartridge not recognized
Try to press and hold the resume button for 5 seconds.
Posted on Oct 19, 2009
gammaray1022
  • 30 Answers
SOURCE: Canon S300 printer. 7 orange blinks, 1 green. I
According to the manual found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=330&modelid=6609
7 orange lights represents a bad print head, and the printer will need serviced or replacement. Since printers are so cheap lately, I would just go shopping. Hope this helps! Thanks!
Posted on Oct 21, 2009
Ip1980 is blinking 7 times orange light and 1 green
7 times orange 1time green
Problem: Black or color cartridge
Aug 13, 2014 | Office Equipment & Supplies
My canon iP1980 printer is blinking orange light 7 times then 1 green. what should i do?
Try to use another cartridge (borrow from another printer first)
This should fix your problem, I hope.
Jun 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Oct 21, 2009 | Canon BJC S300 InkJet Printer
My pixma IP1980 ahs an error and the green at orange lights blink alternately. error code is 6000.. pleasehelpme...
Error code 6000 mean line feed error. Possible problems in:
- Timing sensor unit
- Timing **** disk film
- Feed roller assembly
- Platen unit
- Logic board assembly
- PAPER FEED MOTOR
Oct 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Yellow light blinks 7 times with 1 long green blink
Jennifer, According to an answer by kev1952 on 19 Sept, to my similar error condition ( "repeating sequence of 7 orange and 1 longer green flash of power LED" ) in a Canon i550 printer, and assuming that what you called yellow I called orange, then you too may have a printhead fault. kev1952 recommended to try to get it cleaned and checked at an ink refilling specialist service.
gp26, on 21 Sept 2009
Aug 17, 2009 | Canon PIXMA iP1600 Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
May 05, 2008 | Canon BubbleJet i550 InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
389 people viewed this question
old marine
old marine
