Question about Stihl Garden
The rewind spring for the pull start came out. What is the trick to rewind it???
    Sergeant:
  • Stihl Expert
  • 417 Answers
Put the housing end in first, take the spool and hold the spool end against it and wind the spool in the air until the spring is wound tight, then install the spool back into the housing. you have to keep your fingers on each end of the spring and hold the spool relatively close to the housing, obviously, but it's not a hard trick to master.
Posted on Nov 23, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: rewinding starter spring on chainsaw
I was able to rewind the spring steel coil, but it took 2 people, one at each end, to wind it tightly and hold it tightly enough to fit back into the casing. The bend at the end of the coil must be re-inserted into its own retainer. It was not easy, and it takes some time to get this done. RH
Posted on May 05, 2009
rowdy45176
  • 2176 Answers
SOURCE: Is there a trick to attaching the rewind spring to the pulley?
On the end of the spring there would be a loop or some other manner to attach to the pulley. Usually what you have to do it wind the spring tight (not to breaking point) and then put the loop into a slot in the pulley and push down while inserting the screw and washer to hold it in place
Posted on Jun 22, 2009
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
SOURCE: my pull cord ripped, and the spring came out how
I hope you have strong hands. Start by holding the inside end of the spring in one hand, then carefully wind the spring back into a circle tightly until you get to the other end. The finished diameter of the spring must be a little smaller than the area it goes back into. Put it back in, then replace the pulley like it was when you disassembled it.
Posted on Sep 27, 2011
2000 Sportsman 500. How do I reinstall spring on rewind start cord?
An easy way to fix a pull start recoil spring . - YouTube
? 8:48
https://www.youtube.com/watch?v=d4r8wbejHXY
Feb 19, 2013 - Uploaded by chaseme81871
Thank you so much! I was able to find the pull cord at a local home depot store and when when my husband ...
How to rewind a pullstart spring - YouTube
? 5:05
https://www.youtube.com/watch?v=qTcL3_3leTk
Mar 13, 2010 - Uploaded by lenniepincher
If you ever need to rewind a un coiled pullstart spring. ... ( NEW VERSION ) How to Rewind and Replace Recoil Starter Spring - Duration: 3:53.
Nov 24, 2015 | Polaris ATV
Pull start cord won't rewind model no RLT30CET curved shaft electric start
There is a spring there you don't need to buy one use the old one.. If you need one go online give them model number have in two days.... Good luck..
Sep 15, 2012 | Garden
DO I NEED SPECIAL TOOL TO REFIT COIL SPRING WHICH CAME OUT WHEN FITTING STARTER PULL CORD
There are special tools made for this job, however not needed for most jobs (makes easier). Clean the spring and lube slightly with silicone spray or light oil. Catch the end of the spring that would be the outer end onto slot or pin and slowly spiral the coil into place holding down coils as you turn(dont try to coil the spring then drop it in, take your time as you wind and maybe ask a freind to lend a third hand if your fingers get tired, once you start you cant stop). The inner part of the coil has a bent hook that will catch on the inner portion of the pull rewind. Lood at how the rewind catches this hook by turning the rewind in the direction that it turns when you pull the rope. When you pull the rope it winds the spring. If you put the spring in backwards the rewind spring will not catch. Once you got the spring in place, turn the rewind in the direction that it turns when you pull the rope until it stops, then release one turn and insert rope thru guide and into spool to tie knot. Slowly let rewing pull in new rope. Good luck
Aug 23, 2011 | Electrical Supplies
How to repair a poulan pp 136 trimmer? The rope to start won't rewind.
Most likely you have a broken return spring.whitch will involve removing the blower cover and putting in a new spring,and then reloading the tensionon it.there is trick to that but its hard to explain....you have to tuirn the rope holder the oppisite direction you want it to pull the rope in ,then you feed in the rope while holding the spring loaded then tie the string in and let go...Normally 4-5 rounds will do for a good recoil..Hope it helps
Aug 27, 2010 | Poulan Garden
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
The started cord will not recoil
remove the top cover. take the three or four screws out, turn cover over, the spring has broken or slipped. if it has slipped, remove the cord by untying the knoe in the handle, pull the cord from the inside of the pulley, remove it completely, hand rewind the spring in the opposite direction that it pulls in, holding it is a trick, get someone to hold it after you rewind it, rethread the cord thru the cover hole and thru the hole in the pulley, tie a knot in the end, pull it into the pulley and slowly release the pulley, carefully. put the handle on and replace the cover on the machine.
Sep 18, 2009 | Garden
The pull cord will not rewind
Sounds like the rewind spring has broken or the starting spool is broken or the piston is stuck. You will have to take the machine apart to see what it is that stops it from rewinding. I'm thinking spring.Good luck...Lee
Sep 09, 2009 | Poulan Garden
The pull start needs rewinding, the pull start came lose and goudged a groove in the fly wheel.
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Jul 14, 2009 | Garden
I waz starting the awn mower and had resistince from the pull cored so i pulled and now the pull cored is dangolling and want trigger a start
Soundas like the rewind spring is broken. Remove the top housing and see if you can reset the spring by removing the cord, hook up the broken end, rewind the spring with a screw driver...lock it in the tension position and then reinstall the cord.
Jun 15, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
47 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
