Question about Motorola AXU4100 (10 Channels) 2-Way Radio
Reset radio to default channel settings
I got button pushing happy on our AXU 4100, and can not longer transmit or receive on our primary channel. While trying to fix the issue, I was able to talk on another channel with another radio, but only that one radio. Is there a way to reset the radio back to default settings, or is there a way to re-program it manually to restore it back. And how do I do this???
  • mcnutta May 14, 2008
    I HATE YOU AND YOUR FAT FINGERS
  • Motorola Master
  • 1,654 Answers
Http://www.essnashville.com/CP125_20UserGuide101507.pdf Read pages 19-21 for programming the programmable features of the AXU or CP125.
Posted on Jun 24, 2008
Accidentally set my TV to factory defaults
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 04, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a galaxy 73v that transmits on oe channel recieves on another
common problem bad solder joints in the vco circuit take it to a PROFESSIONAL
Aug 21, 2012 | Galaxy Radios DX-73V 40-Channels Base CB...
We just purchased the Motorola RDU 4100 radios. 8 of them to mix in with 4 others of the same model number. radios were working fine up until recently when 3 of the radios are now broadcasting the same...
Reset to Factory Defaults (Pg. 34)
Reset to Factory Defaults will set back all radio
features to the original factory default settings.
To do so, press PTT, SB2 and SB1
simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
Aug 15, 2011 | Motorola RDU4100 Two Way Radio
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
Uniden Oceanus not transmitting
You may have a sub-channel/privacy channel activated. Unless the person/s you are trying to talk to have the same channel and code set they will not be able to hear you. Check your manual for specific instructions on how to reset it to the default.
Jun 11, 2009 | Uniden Oceanus DSC Wham ready Fixed Mount...
Midland GTX800 "X-Tra Talk" 2-way radios will not transmit
Are you sure that the batteries are running well?
Try using alkaline batteries just for testing.
Jan 17, 2009 | Midland 20-Mile, 22-Channel FRS/GMRS 2-Way...
Motorola Talkabout FV700 not transmitting nor receiving
had the same problem...took out nimh...replaced with triple A...works great!!
Thank you!!
Dec 26, 2008 | Radio Communications
No transmitting with Raymarine Ray45VHF
Re your queries:
1. how to memorize channels?
The channels are pre-programmed that a channel number corresponds to a frequency setting. Ex. Ch16 is 156.800 . If for some reasons some channels are missing, perhaps your best course of action is to reset the unit to factory default, that way everything would be back to  normal. Master reset is performed by pressing the 16PLUS button while powering the radio. The LCD will display "CL" indicating that the memory has been cleared.
If you  want to memorize a certain channel/frequency, you can only store it as a replacement for 16PLUS assignment. Ex. Instead of Ch16 as your priority/emergency channel you want say Ch14 (156.700), you can do this by pressing the up/down key till your desired channel; press & hold the 16PLUS key for 3 seconds or until you hear the confirmation beep that your desired channel has been memorized in the memory as the new 16PLUS.
2. Why I cannot transmit?
There could be 2 possible reasons:
2.1 You are transmitting on a channel that has been assigned as receive only. Examples are the weather channels, Channels 1,2,3,  also 70,75,76, and possibly others.
2.2 Your TX module/circuitry has a problem. More often it is the finals that gets burned.
3. When i use the PTT Channel 16 is automatically set ?
The mic has an identical 16PLUS button (similar to the radio's front panel). If you pressed the PTT switch on the side and the radio switches to Ch16 (as if you pressed the 16PLUS button on the front) then you have a wiring problem from the mic to the radio. Possibly a shorted or open connection.  It is also possible that you have a break in the small PCB (in some versions) inside the microphone.
The user's manual can provide a more detailed instruction.  It is available at the RayMarine website and the link is >
http://www.raymarine.com/SubmittedFiles/Handbooks/Legacy_Handbooks/communications/RAY45MANUAL.pdf
Hope this be of some help/idea. Post back how things turns up or should you need further information.
Good luck and kind regards.
Oct 13, 2007 | Raymarine Ray45VHF (53 Channels) 2-Way...
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Feb 08, 2007 | Motorola Talkabout T5720 (7 Channels)...
Motorola AXU4100 (10 Channels) 2-Way Radio Logo
326 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
