Question about Honda Pressure Washer PSI 3000
I will have low water pressure supply from source. how do i adjust for this? model GX200 with model Annovi Reverberi xtv 3g.22 pump
    President:
  • Honda Master
  • 1,383 Answers
Low water pressure from source is generally not a problem unless water hose to washer collapses when use. You only need to supply the pump just 3 to 5 gallons of water per minute. Easy to check. Just open water supply to hose and capture water flowing out of hose into 5 gallon bucket (capture water in bucket for 1 min., should pretty much fill it ). Just use as normal. Good luck
Posted on Sep 06, 2010
Water won't go through pressure washer, even with the water on and the pressure hose off the machine, no water comes through the pressure washer.
Back behind the water outlet tube are components that have small orifices that become clogged from lime, clay, mud and other contaminants. Mud and clay mostly from well water. I've had over 60 pressure washers in the past three years. I bought them because they didn't work and I would repair the pumps unless they were cracked, then I would buy new pumps to install. It would help to know the pump model details or even the make. Faip, Himore, Annovi Reverberi etc...or even the pressure washer model number as long as it is the original pump. If it is an Annovi Reverberi then it could also be a bad shutter valve. Now there is a revised design of the shutter valve. The part number for that valve is AR42497.
May 20, 2015 | Garden
My pressure Washer Pump Leaks water and does not pump normal?
If the pump is leaking water then you have a packing issue. this will cause a loss of pressure as well...check out here for parts Pressure washer parts catalog quick links Pressure Washers High Pressure... also check out here for specs and diagrams http://www.arnorthamerica.com/pumpbd.html
Aug 27, 2014 | Annovi Reverberi Garden
Need diagram of Annovi Reverberi RMW2.2G24 Pump
Hey there
Here is the a link to the company site for manuals as well as breakouts. Good luck
Jeff Annovi Reverberi Pump Breakdowns AR North America
Jun 04, 2014 | Annovi Reverberi Garden
Drawings
Here is the link to the site for Breakouts as well as manuals. Good Luck
May 07, 2014 | Annovi Reverberi AR RMW2.2G24 Pressure...
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
Model CPW 1800 2 lance guns have developed leaks when pumping against dead end. Do these washesr have a pressure relief valve . Can this be replaced?
Byronj25, you can get the internal part that has most likely failed here. http://www.sparesgiant.com/p-4993-annovi-reverberi-210-gun-valve-kit-with-o-s-2291.aspx. You may want to dismantle it though and check that the black elbow tube has not failed also, as that part is obsolete and so would require a full new Lance. New Lance link http://www.sparesgiant.com/p-5002-champion-cpw-yellow-hl2-annovi-reverberi-gun-large-bayonet-40409.aspx
May 21, 2011 | Annovi Reverberi Garden
Annovi reverberi triplex preesure washer pump
Usually when a pressure washer is pulsating, either one or more pistions are not pumping. Quite often one of the check vavles for a cylider has broken and will not seal, which means you'v just lost one cylinder, and now you're running on two (etc) If a pressure washer is allowed to idle too long, re-circulating the water, it will get hot, and then melt the plastic container on the check valves. Go to : www. pressure-washer-parts.com You can order parts, and manuals.
Jul 15, 2010 | Annovi Reverberi 4000psi 4gpm Pressure...
How do you adjust the chemical feed on a Annovi Reverberi pressure washer pump?
your chemical feed works on most units on low pressure. there should be a adjustment nob red on the intake unloader. if not its preset
Oct 10, 2009 | Annovi Reverberi Garden
Honda Pressure Washer PSI 3000 Logo
374 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
