I have a BENQ 611c Projector which when connected to my Dell Inspiron 1545 ( OS Vista) immediately causes the Laptop Screen and Projected Image to 'shrink i.e. it is no longer 16:9 ( I thi nk that is the ratio) but becomes a smaller SQYUARE. Yet when I connevct the Projector to my Inspiron 1515 ( OS XP) it works fine.
  • peadar177 Sep 06, 2010
    I hsve looked at your suggestion and at first it seemed very likely. However, I have just started my Inspiron Laptop, entered my password and opened up my normal welcome screen but I press Ctrl+Alt+F12 and NOTHING happens. Have I understood you correctly+
  • 11,800 Answers
The display properties are set incorrectly - it's set to Clone and the resolution is set to that native to the projector(800x600).
Access the  Intel® Graphics Properties window (press Ctrl+Alt+F12 keys) and in there make sure that the Clone  system is selected (even if Extended is the recommended one - but Clone is easier to use) and that the Primary device is the laptop's screen and the Secondary device is the projector.
Posted on Sep 06, 2010
  • Azrael SRL Sep 06, 2010
    In that case access it from
    Click Start.
    Click Control Panel.
    Click Appearance and Personalization, and then Personalization
    Click Display Settings.
    Click Advanced Settings.
    Click the Intel Graphics Media Accelerator Driver tab.
    Click the Graphics Properties button
Have gigaware pico projector. When I connect to new Dell Inspiron laptop, Windows 7, screen goes black. Pico suggested resolution of 800 x 600, & 60 Hz for frequency?. Changed resolution prior to
You can choose either.
If you select duplicate, it is useful when you have to give a speech or lecture and you are facing the audience because the projected image is behind you and you can also see the image on the laptop when you face the audience.
The display frequency can be changes in Control Panel - Display
Mar 02, 2013 | Computers & Internet
I have dell inspiron 1545 ultimate & window 7 it was before vista.Now blue tooth is not working please help me out.
Upgrading your laptop OS from Vista to Win 7, you have to reinstall your Bluetooth drivers for Win 7 OS(ie x86bit or x64bit) for the Bluetooth to function properly.
Dell Inspiron 1545 download @ http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1545&os=WLH&osl=en&catid=&impid=
Under "Network" -> Select your correct Bluetooth drivers versions for your OS Win 7 (i.e. x86bit or x64bit) to install.
Hope it helps.
May 21, 2011 | Computers & Internet
All i want to know is HOW DO YOU REBOOT A DELL INSPIRON 1545 TO FACTORY SETTINGS I DON'T HAVE THE MONEY TO TAKE IT IN.
Windows Vista: Dell Factory Image Restore
  1. Turn on the computer. When the Dell logo appears, press several times to access the Vista Advanced Boot Options window.
  2. Select Repair Your Computer.
The System Recovery Options window appears.
  1. Select a keyboard layout and click Next.
  2. To access the recovery options, log on as a local user. To access the command prompt, typeadministrator in the User name field, then click OK.
  3. Click Dell Factory Image Restore.
note.gif NOTE: Depending upon your configuration, you may need to select Dell Factory Tools, then Dell Factory Image Restore.
The Dell Factory Image Restore welcome screen appears.
  1. Click Next.
Nov 09, 2010 | Dell Inspiron 1545 Notebook
Dell 4100MP Image Not Centered Thru Lens
No to your question. The lens is fixed it cannot shift horizontally only although there are projectors that can do this. I am sure you have the front foot retracted? I have had to do the same as you are doing or find a lower table.
Jun 02, 2010 | Dell 4100MP Multimedia Projector
Laptop screen image is truncated on data projector display (Dell)
Had the same problem, tried a Factory Reset from the menu and it seems to have worked. Don't know what caused in in the first place
Nov 11, 2009 | Dell Office Equipment & Supplies
My Dell Inspiron 1545 shutt down by itself...
Not necessarily, there can be all kinds of reasons for OS corruption.
  1. Run the hardware diagnostics from the F12 1 time boot menu or hold the Fn Key while pressing the power button. See if you have any hardware failures. If so call tech support.
  2. Since it is prompting to reinstall the OS, you can Re-Image the system using CTRL+F11 and the Dell Splash Screen for windows XP, or off the F8 menu for Vista
Oct 06, 2009 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 power adapter not charging machine
if it is under warranty please take it to the service center if you try doing anything by yourself that may damage the warranty and it may pinch your pocket,
Aug 08, 2009 | Dell Computers & Internet
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
The image projected from my CTX EzPro 680 Projector flickers on screen
From my experiences working with projectors, more than likely you will need to replace the lamp
Oct 04, 2007 | CTX Optoma EzPro 680 Multimedia Projector
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
