Question about Frigidaire Dishwashers
The door of the dishwasher is leaking. It seems that the door maybe broken as when you it is open it does not stop until it is past the 90 degree angle. The model# is FDB520RHS0.
  • davidlhought Sep 06, 2010
    Would I just tighten up the hinges?
    Ok, it does not seem to be the hinges. The only issue I see is that the springs have been overstretched so that when the bottom drawer is pulled out full it drops it to an angle greater than 90 degrees.
    On the leak, I pulled off the cover of the door and the base of the dishwasher actually extends past the door and there is a lip there that makes it look like it is expected that water would get through except what is happening is that the water is getting shot out from under there with enough pressure that is going up over the lip and leaking onto the floor.
  • 11,896 Answers
I would check the hinges, and check the door gasket.
Posted on Sep 06, 2010
  • Nate Stansfield
    Nate Stansfield Sep 06, 2010
    You can tighten the screws. If the holes are stripped out, you may have to go with a bigger size. If the hinge ends up to be broken, then it should be replaced. Try partselect . com
  • Nate Stansfield
    You can try and put an waterproof high pressure adhesive on the seal. Or replace it all together. For the hinges, looks like new spring are in order. You can get them along with diagrams and more at partselect . com or daysappliance.
The door on my Frigidaire dishwasher recently began opening too far. It slants toward the floor, a few degrees past level. Looking at it, however, nothing seems to be broken or missing. The springs are...
I have the same problem. The springs look intact. Maybe some stepped on the door when it was opened and it stretched the springs. I'm going to replace them and see what happens
Jan 14, 2011 | Dishwashers
The 2 metal "clips" that secure the dishwasher to
door gasket possibly bad or another leak. Stop using dishwasher until repaired or you're likely to ruin your floor. I just had this problem before we found a leak and now we may have to replace the kitchen flooring.
Order new clips or the dishwasher could fall out onto the floor or even onto your foot.
Nov 16, 2017 | LG LDF6920ST Stainless Steel 24 in....
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Powdery residue leaked out of bottom of door. I thought it was soap so redid dishes with no soap and now just a smaller amount leaked out mixed with a little water. I though maybe the dispenser was...
the water with sop might still in the pump that is way you still see sop, but the leak might come from the seal of the door or the spray arm :
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Nov 27, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Water leak from door
Nov 11, 2009 | Maytag MDB7100AWB Dishwasher
Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
May 16, 2009 | Haier Dishwashers
Door hinge spring broken
Yes, it can be fixed. Sounds lilke just a matter of either fixing or replacing hinges/springs.
May 10, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
We have a +11 year old Bosch SHU3006/UC/U06 that never leaves the wash cycle. We had to stop it during our last test run at 3 hours. Chat advise is suggesting a water temperature problem (I origionall...
Check continuity of the heating element to see if it is broken/open.
The dishwasher prefers that the incoming water (water heater) be 120 degrees (F)
Apr 04, 2009 | Bosch SHU3036UC Dishwasher
BF1620 leaking dishwasher leaking help.
hi,Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
Aug 06, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
