Question about Acer Aspire 5003WLMi Notebook
Acer laptop Screen is white. Power is on. What should be done to repair?
  • 1,031 Answers
If you can open the laptopscreen from the back by loosening it check the silvercable that is attached to the screen form the board if its loosed you can insert it properly so that the screen can display
Posted on May 13, 2008
White screen, whats the problem of my laptop?
> white screen
Usually, this is a bad/intermittent connection (via a ribbon-cable) from the motherboard to the LCD screen. Open/close slightly the hinged LCD screen, to see if you can find a "sweet-spot".
Or, take the computer to a qualified technician, for professional trouble-shooting and repair.
May 22, 2011 | Lifetime Acer Aspire 5810TZ-4657...
After falling my acer aspire laptop it is working properly but its screen is completely gone white from the right side.please help
Unfortunately the only option you have is to have the LCD screen replaced, they are easily damaged in a fall and there nothing more than can be done. But the video cable from the motherboard to the screen might have been jarred loose and should be checked.
Mar 22, 2011 | Computers & Internet
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
My acer laptop screen turns white while working
Try reinstall the video drivers as it looks like an issue with the video adpater. To do so:
Start Menu> All Programs> Acer erecovery management> Restore> install Application & Drivers> Select the appropriate Video driver (Intel, NTI etc as per your computer spec) and install it. Restart the computer and check, the issue should be resolved. If not, then I am sorry I bet the computer needs repair.
Jul 01, 2010 | Acer TravelMate 2300 Notebook
My laptop screen turn into white
The possible cause of your problems is:
detached or broken cables connecting to your mainboard and LCD screen.
or defective power supply
I suggest you find a qualified servicemen to repair you laptop
Thanks. Cheers!
Apr 21, 2010 | Computers & Internet
My acer aspire 5520 comes on then turns off how do I fix it
I've already solved my problem, and it maybe help somebody with the same trouble...so there you go:
1st step: Let the laptop turns on and off itself until it's screen turns to a white blank one
2nd step: Power off it
3rd step: Power on tha laptop. It will start normally and give you two options of startup
4th step: Choose to start the "recovery test", then it will repair any error and will start Windowsmag-glass_10x10.gif normally
Well, that's what I've done to recover my Acer...
Jan 19, 2010 | Acer Aspire 5520-5908 Notebook
Purchased a Acer Aspire 2930z. i get a blank white screen.
Connect an external monitor to your laptop and power the laptop up, if you get a normal image on the external monitor then you have a faulty LCD screen and may be replaced. If you still get a white screen then you most likely have a faulty video card.
The video card is part of the motherboard and usually cannot be repaired, the motherboard is normally replaced but it may not be cost effective to replace. If the laptop is a several years old then it is time to get a new one.
Mar 08, 2009 | Acer Aspire 3610 Notebook
I hav problem with my acer aspire 4710. it screen turns white.
ACER PICTURE PROBLEM – MY SOLUTION
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
http://www.insidemylaptop.com/category/1-acer-laptops/
Hope this helps. (Please rate my advice)
Jan 30, 2009 | Acer Aspire 3610 Notebook
ACER blank screen
your lcd screen maybe damage due to impact i suggest you bring it to the computer shop for repair. most common damage are the screen and harddrive due to strong impact.
Oct 16, 2008 | Acer Computers & Internet
Acer Aspire 4315-2004 Notebook
hi. sir..
please istall ur aperating system once again and try it.. it may be helpful.. thank u sir.. for any assist i am there .
Sep 07, 2008 | Acer Aspire 4315 Notebook
Acer Aspire 5003WLMi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
