Question about Razer Tarantula RZ03-00070100-R2U1
None of the keys work on there own but they do work when pressed with another key at the same time. please help eric
I bought and hp laptop but in every time i want to open microsft office home and student it tells my you have to put your product key
Have you put in your key? Current versions of Office come in a trial version that will work 25 times and need the key put in after that. It will ask every time before that to give you the chance to put in the key before the trial expires.
Jim
May 01, 2011 | Computers & Internet
Hi I have an aspire one laptop but all of a sudden the screen has stopped working but power is going too the computer please help, do u think it could be a loose conection at a solder point connecting the...
Hi
have you by any chance pressed one of the keys on the top row of the keyboard by mistake
one of those keys will turn on/off the screen some laptops the key is F7 or maybe FN+F7
another option is
turn off laptop
press power on key and at the same time press the F8 key a few times and it may take you into
the repair options and you could try some of those options in there
if none of these work
another option is
press the power key then press ALT+F10 and this may take you into the recovery option
then follow the onscreen instructions
good luck
hope this helped you
Mar 27, 2011 | Computers & Internet
The touch pad was working and now all of a sudden its not
Check your model for a mouse pad disable key. A lot of times it is right above the mouse pad (and is easily bumped) or a function key. It generally looks like a symbol of two mousepads with the second one having a line drawn through it.
Try pressing this button or holding in the Fn key (lower left hand corner) and pressing the function key and see if that resolves your issue.
If not make sure mouse drivers are installed and working properly.
If none of this helps, please post your model and Windows version.
Please leave feedback if this was helpful.
Mar 23, 2011 | Computers & Internet
Keyboard trouble
you need to reload that software that came with the keyboard. Uninstall the keyboard from device manager :- Control Panel>system>device manager. Then reload the software for the keyboard, which should also have the drivers. If you do not have the software, let me know the make and model of the keyboard and I will see what I can do.
Hope this helps
Oct 28, 2008 | Gateway Computers & Internet
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
REMOTE DONT WORK WITH MY TV
hi go here for the complete usermanual, and try thid following.
If none of the codes listed under
“Device Codes”on the back of this
guide match your device, you can
search for a set of commands that will
work. Your remote will sample all the
codes in its system for that device
mode to find one that will allow you to
control your device.
1. Press and hold a device mode
key (AUDIO, DVD/VCR, or TV) for
at least six seconds. The LED for
each device key lights up, then
the key for the device you
selected remains on.
2. Press a function key (such as
Power or Mute). The following
function keys are valid for
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
The device key’s LED blinks
three times, then turns off.
3. Press !. The remote will send
the IR command for the function
you pressed in Step 2.
4. If the device performed the
function you pressed, press OK.
The remote will now control the
device you selected in Step 1.
If the device did not perform the
function you pressed, repeat step
3. Press " to retry the previous code
I hope this helps
Please rate accordingly
Thank You
sserpentio
Mar 28, 2008 | Motorola Mobility DRC800 Universal Remote...
Remote dont work with my tv
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
I hope this helps
Thank You
sserpentio
Razer Tarantula RZ03-00070100-R2U1 Logo
22 people viewed this question
Top Razer Computers & Internet Experts
Alun Cox
Sunday Ojelabi
Sunday Ojelabi
Larry Chandler
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
