Question about Sharp AR-M620N Copier
I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't know how to enter them...does anyone know the procedure to enter these codes. Thanks
  • 26 Answers
* Entering the simulation mode
1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key or EXECUTE key to start the simulation opera-
tion.
To cancel the current simulation mode or to change the main code
and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Posted on Sep 07, 2010
My sharp machine ar 5516s is having problems giving error code l and 4 simulteniously what can i do
i hope its L4.If it is showing
L4 it means the main motor is locked(failing to move) Check all the moving parts including the drum unit, developer unit, main drive unit and fuser unit if they are moving freely. If they are moving freely change the main motor
Jun 18, 2014 | Sharp AR-5320 Black and White Copier
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
On a sharp arm 257 can you a drum unit or just blade and drum
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Jun 03, 2009 | Sharp AR-M237 Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Drum replacement
simple - service code 24-7 will rest drum, sevice 42-1 will rest deveolper service code 20-1 will reset serice indicators you can get a service manuel at persision roller in phx arizona and all parts
Feb 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
May 22, 2008 | Sharp AR-M237 Digital Copier
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M620N Copier Logo
349 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
