Question about GE WJSR2070B Top Load Washer
The water will not kick off - GE WJSR2070B Top Load Washer
  • 50 Answers
Sometimes the valve in the electronic water switch jams. If you are handy, switch off the machine, and take the top cover off (usually two screws in the back on top.) Switch off the water supply and disconnect the inlet hose. look at the valve where the hose connected. There are usually three screws holding the electrical switch section (identifiable by the two wires connected to it with spade connectors). Take those screws out and carefully remove the switch (there is a solenoid and spring etc inside, so be careful not to drop them, and although it is logical how things fit back in, it is a good idea to note in what order they come out. Clean the solenoid and spring. Push the solenoid in by hand and check that it slides easily. (If not you could apply a little petroleum jelly) If it slides easily, replace all the parts and the water supply hose and test. Should be fine now. Replace the lid.
Posted on Sep 06, 2010
Push buttons to dishwasher and water does not kick on, what would cause this.
Their are a few steps check to get the water to "kick on" again.
  1. Check and see if the water was turned off to the dishwasher under the sink -No? Next step
  2. Check if there is soap build up make sure the float can move freely it could be giving a false single that water is filled in the tube. Clean up any build up. No? Next step
  3. Take off the kick panel and inspect the wires leading up to the dishwasher inlet/fill valve. Sometimes mice like to chew on the wires. Clean and reconnect. No? Next step
  4. Change out your Water inlet/fill valve
That should "kick on" your water to the dishwasher again.
Hope your having a great weekend and please rate me.
Dec 12, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Red reset button keeps kicking out, i reset button and works fine for a day or two then kicks out again
The reset button kicks out because the thermostat detects overheating.
Anything over 150 degrees, the reset kicks out.
This is caused by 4 things.
1) Bad upper or lower thermostat. Thermostat sticking in 'on' position and elements overheating water.
2) Factory-installed insulation and cover are removed
3) Bad element shorted to ground at center of element, and element continues heating with 120V through the ground wire.
4) Loose wire near upper thermostat, that is shorting and causing heat.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Solution:
Check for missing insulation.
Check for loose and burned wires.
Replace both upper and lower thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problems continue, test water heater elements and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If you need more help, add a comment and I will respond.
Oct 29, 2010 | Reliance & 40 Gal Electric Mobile Home...
Leaking water underneath dishwasher
most dishwasher has a kick plate at bottom ,,remove kick plate ..be careful turn unit on let water fill system..and just look ..just look and see where the water is coming from...warning,,most parts of a dishwasher are not grounded,,,please be careful
Oct 10, 2009 | GE Dishwashers
Water heater won't run long enough for hot water.
Common problem if the thermo couple goes bad.Replace thermocouple with a universial on.A common hardware item.
Dec 14, 2008 | Water Heaters
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
I have a Honneywell Triple Aquasatat Relay insstalled on by boiler that heats both the baseboard and hot water for my residence. The relay is set so that the low kicks on at 180 degrees and the high kicks...
The temperatures you mention are reacting in a normal manor. The drop in temperature after it first starts comes from the water being brought back to the boiler from the system. The rise in temperature comes from the residual heat in the chamber after the burner shuts off. I would not push the limits on these settings. Water from the boiler is mainly meant as an assist . You did not answer if you have another hat water heater.
May 01, 2008 | Heating & Cooling
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE WJSR2070B Top Load Washer Logo
19 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
