Question about Vivitar ViviCam 3625 Digital Camera
What kind of batterys does it take.. - Vivitar ViviCam 3625 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
The 3625 uses standard AA batteries.
Posted on Aug 09, 2012
Need a battery for my LG phone. serial no. 011436000161052. what kind ? what no.? Thanks
there is different kind of batteries no need of s no . Go to store ask model no battery . There are china made also avilable but i personally say that you take lg battery.
May 04, 2011 | LG Cell Phones
My bluetooth is not working and battery problem please solve my problem
hi there!
If you're having a problem with bluetooth then ill be advising you to powercycle your phone and you can do that by removing the battery on your phone while the phone is on.After that reinsert the battery and turn on the phone again and try turn on your bluetooth again.Kindly check as well if your phone is fully charged because bluetooth will not work that good if the battery on your phone is not fully charged.Kindly check as well if the device your pairing with through bluetooth is compatible with your phone because there are devices that are not compatible with each other.
If the battery is the problem then try doing the rebooting or powercycle process of the phone.If its still not turning on then kindly charge the battery for a maximum of 4 hrs.Please check if the battery is holding a charge.If it still not working after doing that then there might be a problem with the battery.Kindly replace the battery so that you can use your phone.
Thank you!
Apr 20, 2011 | Cell Phones
My e7 nokia is Auto restart problem plz repair this problem
Hi there!
If you're having a problem in turning on your phone then ill be
suggesting you to please remove the battery in your phone then
kindly wait for about 15 seconds.After that please turn on your
charge.If it still not turning on after doing that then there might
be a problem with the battery.Kindly replace the battery so that you can use your phone.If you already replace the battery and you're still having the same problem then there is a probable problem with the phone itself. Kindly contact the manufacturer of your phone.
Thanks!
My nokia 3110c classic phone is not switching on
Hi there!
you're still having the same problem then please check if there
Thanks!
Apr 20, 2011 | Nokia 3110 Cellular Phone
I turn on my phone and when the boost mobile sign appears its just stays there and it doesn't go nowere not even into to main menu or nothing
hi there!
Basically, you're phone is freezing that's why the boost mobile logo stays on and not going to any other menu on the phone.
If you're having this kind of problem then ill be suggesting you to please remove the battery in your phone then kindly wait for about 15 seconds.After that please turn on your phone.If its still not turning on then kindly charge the battery for a maximum of 4 hrs.Please check if the battery is holding a charge.If it still not turning on after doing that then there might be a problem with the battery.Kindly replace the battery so that you can use your phone.If you already replace the battery and you're still having the same problem then there is a probable problem with the phone itself. Kindly contact the manufacturer of your phone.
Thanks!
My mobile not switch on
Hi there!
If you're having a problem in turning on your phone then ill be suggesting you to please remove the battery in your phone then kindly wait for about 15 seconds.After that please turn on your phone.If its still not turning on then kindly charge the battery for a maximum of 4 hrs.Please check if the battery is holding a charge.If it still not turning on after doing that then there might be a problem with the battery.Kindly replace the battery so that you can use your phone.If you already replace the battery and you're still having the same problem then please check if there is a probable problem with the phone itself.
Thanks!
Apr 18, 2011 | Nokia 5130 Cellular Phone
I have a Hitchi Radio/CVD player KC-92CD and I don't know what batteries I need for the remotre
Take out the batteries and check?Very small long tube battery kind?That the AAA kind of bateries.Long tube battery kind?That the AA kind of bateries.Square battery kind?That the 9 Voltage batteries kind.
Oct 21, 2010 | Hitachi Televison & Video
Hi, my olympus digital camera FE-310 (1,6 years old) often indicates immediately 'battery empty' even with fresh batteries. I tried out different kinds of batteries, but the problem seems to get worse...
Make sure you have the right kind of batteries. These kinds of cameras can use the batteries very fast if they are not the correct kind recommended by the user manual. Read the user manual.
If the camera works correctly, and takes pictures and movies okay, and still uses batteries quickly, then more than likely, the batteries must be the wrong kind. Never use the cheapest kind of double-A in these cameras.
If you use rechargeable batteries, make sure they are charged fully before using the camera.
Try this: Turn the camera on, make sure that the menu setting for the kind of batteries you have installed is set correctly. If you set the wrong kind of batteries, the problems you are having is a common thing.
Also turn the camera on, then set all the menus to the default settings. Then make sure that the kind of batteries you are using is set in the menu as (if alkaline set it so... If rechargeable, set so ... other options may exist in menus).
Oct 23, 2009 | Cameras
I find shooting in SHQ that it still drains my battery too fast
More better quality = larger size picture = more information to write to memory. Hence, less shots...
What kind of camera? What kind of battery or batteries? What kind of storage card in camera?
Mar 07, 2009 | Cameras
Vivitar ViviCam 3625 Digital Camera Logo
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
