Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Brush Motor Replacement on 8920
I did get the 2036757. Unfortunately, it did not come with the pulley. The hole in the body of the machine appears to only be large enough to allow the shaft of the motor to penetrate from inside to the outside. Attached to the outside part of the shaft is a small toothed pulley and some cylindrical piece between the pulley and the body of the machine. I didn't know if this cylindrical piece is just a spacer or maybe some sort of locking device for the pulley.
For some reason, when I posted my initial question, this site would not allow me to enter the 8920 as a valid model number. The Bissell site recognizes it, as well as the site from which I purchased the brush motor. Strange.
If you have any advice, it would truly be appreciated.
Thanks,
Josh
    President:
  • 1,673 Answers
Sorry for the delay, the end of the motor shaft is notched, so there must be a C or E clip to take off, then the pully will come off.
Posted on May 15, 2008
I replaced both belts and still the brushes won't turn
Hello, this is Ava with Think Crucial.
You may need to clean your roller brush first and try to see if this would resolve the issue. If not, then most likely your roller brush needs to be replaced.
You may order replacement parts for your Bissell directly to us. This is our Bissell replacement parts: http://www.thinkcrucial.com/collections/vacuums/collection-filter-fits-vacuum-bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 11, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Brushes not turning on 8920 2x Bissell
Brushes are switched on by lowering the handle which activates a micro-switch located inside the lower part of the machine. Vacuum must be running as well. The DC power for the brush motor comes from a Bridge rectifier located on the PC board located in the handle. I have drawings that might help you.
petedcurtis@gmail.com
Nov 26, 2008 | Bissell 8910 ProHeat Clear View Upright...
This the number for the brush roll motor, 2036757, is it the one you got? I don't remember having to remove the pulley, I am thinking that the pulley is on the new motor. The 8920 is a good number? Where you on the Bissell site, or some other site.
May 11, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover Encore Supreme belt replacement
Remove the bottom plate that covers the brush roll and remove the roller. The plate is removed by releasing two clips at the back corners of the plate on either side. Take the roller and install the belt around the pulley and put the other end of the belt through the access hole in the vacuum body. Replace the roller and turn it by haand to ensure that the belt is not pinched. Replace the bottom plate and turn the roller again (same reason).
If you look at the area beside the rear wheel between the hood and the main body, you will see a clip incorporated into the hood. Take a screwdriver and pry it away from the main body. Do this on both sides. You will find a similar clip at the hood just beside the back corner of the plate in the front where the plate clips are located. Pry these as well and hood will come loose. Now you can turn the machine back on its' wheels and remove the hood. You will see the belt where it comes through the main body and you can grab it with a couple of fingers and stretch it onto the motor shaft. Replace the hood and the job is done.
Mar 21, 2008 | Vacuums
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
BISSELL PROheat 2X model 9200
There is a belt on each side(if this is a 9200), if they look ok, then I would suspect that the brush roll motor is bad part # 2036757.
Dec 30, 2007 | Vacuums
Bissell proheat 2x
Yes, there are belts for both sides, but if they look ok, then the brush motor may be bad. Brush motor part # 2036757 , right side belt # 2036804 left side belt # 2036688
Nov 10, 2007 | Bissell 3522 PowerForce Bagged Upright...
Bissell proheat 9200
The brush roll motor is most likely bad (part #2036757). You will have to take it aprt and check it.
Oct 08, 2007 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
