Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Picture bounce or flutter
About 5 minutes after turning on set picture will bounce or flutter on all channels for about 5 minutes after that it's fine.I'm guessing it's a warm up problem but have no idea what to do before it gets worse.
  • 2 more comments
  • boatops May 13, 2008
    No the picture just flutters looks like maybe a triple picture.
    No Dan picture just flutters, looks like triple picture till it stops. Thanks for quick reply Bill
    No color is together. Convergence of three colors seems fine. Just a bounce or flutter on screen. Thanks Bill
  • Lgrib626 May 13, 2009
    While we try to watch a taped show, the channels just start flipping over and over.
In case there is a loose connection and the convergence board is not damaged. This is what I did and worked out "perfect".
My Mitsubishi HDTV Medallion 1080 has been with us for about 7 years.
The TV started showing distortioned colors and images and even when I used the convergence options from the main menu, it would not show clear images until it would be working for around an hour or if we would hit it until the image would fix. It got worst over the time at a point that it would require 2-3 hours working and several punches and kicks.
No doubt dust has done it's job, well, a vacum with a brush end can help resolve the problem.
1. Make sure the TV is off and disconnected from power.
2. Remove the rear cover at the back (it is clear wood colored and is at the lower part of the cabinet)
3. Using a vacum with a brush end, vacum all the dust that you will find. Be cautious not to hit the components and do not or apply preassure while doing the work
4. On the left side, you will see a card over a mother board, make sure to vacum it well and that it is well inserted in the slot (I did apply some preassure to make sure it was fully inserted)
It took me around 15 minutes and my tv is working like NEW.
While you are removing the dust with the vacum, you may want to vacum the 3 lenses as well, again, using the vacum, no need to clean them with a cloth. I saw a thick layer of dust over them and could remove it easily with the vacum.
Hope this will work for you.
Al
Posted on Oct 05, 2008
  • 4,234 Answers
Does the picture quality change at all or does it just move on the screen?
Thanks,
Dan
Posted on May 13, 2008
  • ABRsvcs May 13, 2008
    One more question. Is the triple picture different colors? In other words is each of the three a different color?
    Dan
No Picture - only sound
I have a TV at work that has been doing the same thing here's how I've been getting it to show a picture:
turn the TV on then quickly change it to an input channel (like front or etc) that doesn't have anything connected to it. Let it sit there for a few minutes, then change it to a regular channel and see if you have a picture.
Apr 26, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
Picture flutters and distorted
Capacitors going bad on your DM or FMT board. Very difficult to replace, but Mits does a rebuild on the chassis. I recommend talking to your Mits service center and getting the rebuild done.
Dec 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture flutter
As I indicated (I think) in another string, this sounds more like bad connections than anything else. Try resoldering the pins on the convergence ICs. Let me know if that does not resolve the problem.
Dan
May 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Tube tv bouncy picture
I've seen this problem before, would need your model #, meanwhile is your picute bounce when you hit the if pack, or pip module, if it does that were your problem is. these or your silver cassing, standing upward.
Regards
What About Bob
Feb 18, 2008 | Televison & Video
Is my Toshiba 57H81 worth repair?
Bounce horizontally usually means up and down,which relates
to the vertical output IC. Solder IC301, IC401 pin connects==try
again.You can easily isolate "bounce" problems by lightly
tapping on the vertical IC heatsink....Let me know if you need
further assistance.....T.
PS. Though hard to find, a qualified tech could do that repair
in home for 300. to 400.00...
Oct 20, 2007 | Toshiba 57H81 57" Rear Projection...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Sony KV 20S40 20" tv flutters, reduces in size and then shuts off
The set most probably has cracked solder joints in one of the deflection circuits, which is pretty common. The picture tube and major components are fine. A good tech can quickly resolder the main board and that should not cost too much. If your set came into my shop I would charge about $50 but ask around, the shops in your area will vary.
Jul 31, 2007 | Sony KV-20S40 20" TV
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
600 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
