Question about Whirlpool Duet GHW9150P Front Load Washer
F 02 flashing - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
F 02 flashing on control panel
F/02..
Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Oct 21, 2012 | Kenmore HE3T Washer
My gear is not selecting after the drive.
For Automatic transmission problem,click the link below:----Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Feb 27, 2012 | 2005 Ford Taurus
92 chevy 3500 6.5 auto trans trouble
For Automatic transmission problem,click the link below:----Automatic transmission troubleshooting:---- http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html---------Automatic transmission shift lever issues?------- http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
-----------AUTOMATIC TRANSMISSION FLUID LEVEL? --
-----------Transmission fault light on car dash? http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
--------Transmission shifting problem? http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
--------Transmission Slips out of 2nd gear?
Automatic transmission will not go into reverse? http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
----------Transmission is making buzzing noise? http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
-----------This will help.Thanks.
Feb 22, 2012 | 1992 Chevrolet C/K 3500
1995 isuzu rodeo 5speed transmision shift lever not shifting gears
For Automatic transmission problem,click the link below:---- Automatic transmission troubleshooting:----
Transmission fluid leaking?
This will help.
Thanks.
Feb 15, 2012 | 1995 Isuzu Rodeo
F 02 STARTS FLASHING WHAT CAN I DO TO STOP
i believe that is the code for slow drain condition.pump may need to be cleaned
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
F flashing followed by a 2
F/02 Long Drain
Feb 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Check-engine light on
P1132 is front 02 bank 1 and P1152 is front 02 bank 2
This codes indicate a rich condition. I would check for a dirty air filter or a dirty MAF sensor.
Jan 31, 2009 | 2001 Ford Excursion
No sound flashing e-02 in window
Turn power off this will release the protection turn power back on if code is still flashing contact kenwood dealer
Jan 04, 2009 | Kenwood Excelon KAC-X621 Car Audio...
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
