Question about Hunter Ceiling Fan Remote Receiver 85112-01
What are the dip switch settings on my hunter fan remote currently pin 1,3,4 are plugged in
  • 377 Answers
That is the code that works with your wireless remote controller. The switches should be set the same in the remote in order for the wireless remote to work.
Posted on Sep 06, 2010
How do I find the dip switch settings for my Hunter fan remote.
Look in the fan's receiver. Make the dip switch positions the same in the remote as it is in the receiver.
Apr 16, 2017 | Hunter Dryers
How to set dip switches in hunter ceiling fan remote 85094-02
Fan switches and remote switches must "mirror" each other, otherwise fan will not operate properly or if at all. For instance: if switch 1 in remote is set "on", then switch 1 in fan must be set to "on".
Jun 25, 2015 | Hunter Dryers
How do I get the remote to work fan and light
There are dip switches in the fan and in the remote that need to be set to the same numbers. You can set them to whatever you want, as long as they match. If these numbers don't match it won't control your fan.
Here's a few lines from the user manual:
"IMPORTANT! Before installing this control, check the factory dip switch settings. Refer to Figure 1. Be sure the dip switch positions of the transmitter and the receiver match, or the ceiling fan will not function."
Here's a link to the PDF manual, which has an explanation and a figure in the middle of where you can locate these dip switches on the transmitter and the receiver both.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/41316.pdf
Jun 24, 2014 | Hunter 27185 Remote Control
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
We installed a 27185 remote kit in a hunter fan, and factory settings. The fan light goes on and off by itself. I changed the dip switches( matched them to the remote to the controller), and the fan and...
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
Jul 09, 2010 | Hunter 27185 Remote Control
I tried to change the remote codes on the fan and remote so it would stop turning on and off the fan in the other room but I can't get it to work.
When I changed the dip switches on the Hunter receiver, I noticed that the remote would not work when set to the new code. When I set it back to the previous code, it would work, leading me to determine that the receiver has some basic memory. The solution was to simply cut the power to the fan at the circuit breaker box and the new dip switch settings now work.
This was not described anywhere in the manual of the Hunter fan I purchased, so a slight oversight by the manufacturer.
Oct 12, 2009 | Hunter 27185 Remote Control
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
Jun 24, 2009 | Hunter 27185 Remote Control
Dryers Logo
668 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
