Question about Maytag MZD2766GES Side by Side Refrigerator
I HAVE A MAYTAG MZD2766GE, PROBLEM IS THE COIL IN THE BACK OF FREEZER AREA KEEPS ICING UP SOLID AND NO COOLING TO FRIDGE OR FREEZER, FAN IS WORKING , HAPPENS ABOUT EVERY 2-3 WEEKS. IS IT THE HEATER OR DEFROST TIMER, AND IF SO WHERE IS THE TIMER LOCATED?
  • 2 more comments
  • z28rr Sep 06, 2010
    tested heater and it read 230mohm, so it appears to be ok, it also has a small device that clips to one of the freon lines, that is included with the wiring harness for the heater element. Is this some type of sensor and if so what is its purpose and could this also be a problem as it looks like power has to go through it to get to the heater? thanks...rick
    hi thanks for the advice, the sensor is reading a high ohm reading at room temp, so i guess thats where i should start. it is a complete assembly including the heater so i would assume it comes with the heating element as well.is it possible it could be both the sensor and the timer or just one? thanks..rick
    thats great! thanks for the info...Rick
  • z28rr Sep 07, 2010
    VERY HELPFUL, THANK YOU VERY MUCH!!!!
  • 6,784 Answers
HI. There are two causes here, in this situation. The most common will be a faulty defrost timer, or adaptive defrost control board. The defrost mechanism will vary form unit to unit. Most newer units will be equipped with an defrost control board. This will be located in the control housing, just above the heat shield, in the upper right had side. Older models will have a standard defrost timer mechanism. If this device fails, the evaporator heater Assembly will not receive the command to defrost the coil, on time. The easiest way to isolate the cause, will be to test the heater element. If the element is functional, the defrost timer/board, will be the culprit.
Defrost heater assembly test procedure:
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice-maker and the inside rear or bottom panel of the freezer, to access.
The panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. On some older top freezers it is necessary to remove the plastic molding to access the freezer floor. Removal of that molding can be tricky, so try not to force it, if possible. If you decide to remove it, you do so at your own risk. it will break, if forced. Warm it first with a warm towel, or hair dryer, set to low heat.
There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely faulty, and should be replaced.
Posted on Sep 06, 2010
  • 2 more comments
  • Michael Masters
    Michael Masters Sep 06, 2010
    Click here to view an exploded diagram of the unit control housing in the refrigerator compartment. You defrost control device will be labeled number 13 on the diagram provided. The heat shield will be labeled number 19 and the Control housing will be labeled number 1. If the heater passes its respective test; replace the defrost control board.
  • Michael Masters
    Your are correct Rick; That connected device is a sensing thermostat that works in conjunction with the control board to regulate proper heater functions. This device is integrated into the entire heater assembly. A simple resistance test or continuity test can be performed at the thermostat terminal harness to verify proper function. Separate the thermostat device connecting wire harness and preform the test as follows:
    • To test the thermostat; Set the multimeter to the ohms setting X1. Touch one probe to each terminal inside the wiring harness connector that runs to the thermostat and not the heater. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostat is cooled to the limit temperature, it should switch on and you should get a reading of infinity. Replace the thermostat if it fails to register as described.
  • Michael Masters
    In this case, I would hold off on purchasing the control device. The heater assembly will be the culprit and not your defrost control board. The actual test results have confirmed the local damage that has affected the heater assemblies normal abilities. It is now safe to purchase the replacement heater assembly.
  • Michael Masters
    No problem. If you need any more help, feel free to ask..
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
How to repair fridge where freezer not cooling
usually just a build up of ice over a period of time. Make sure the condenser is clean and all fans turning at full speed. If symptoms persist, manually defrost every now and again
Jun 08, 2014 | Maytag Refrigerators
There is no cooling in my fridge but fridge is on,fan is working but no cooling
it can be any of 3 issues,either the damper vent door between the freezer and refrig is iced up and cant open and close,or the motor that operates this door is bad or without power,then the evaporator coil in the rear area behind a panel inside the freezer is iced over and you can't blow cold air over a solid wall of ice,if this is the case the rear wall inside the freezer will have ice buildup on it,then it can be a bad ptc contactor overload relay on the compressor keeping it from starting and cooling the unit
Nov 16, 2010 | Whirlpool Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Sep 05, 2007 | Maytag MSD2454G Side by Side Refrigerator
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
868 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
