Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
I have this Miller Big Blue 400D Generator welder. Deutz 3 cyl engine. The engine started and run. But the generator/welder NOT function. we are trying to repair it but we don't have the Schmatic Diagram. pls sent me the SCHMATIC DIAGRAM. Thx
Go to the miller website and download the manual. the scematic is in the manual
Posted on Mar 29, 2011
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Gas runs out of carb drain on miller welder generator 301g trailblazer
if it is the float bowl drain leaking, close the drain. If it is the vent, clean float bowl and needle and check level. Next time, drain the fuel out of float bowl after you run it if not planning to run it for 30+ days. That is why they put drains on generator carbs. Modern ethanol turns to gum real quick. Tell you congressman you think ethanol sucks and the new 15% ethanol the farm lobby is trying foist off on us is going to be a disaster for small engine owners.
Apr 10, 2013 | Miller Trailblazer 301g Cc/cv, Ac/dc...
I need the part number for the termial output and ground for my 302 diesel Trailblazer and a part number for the starter motor for my 400P Big Blue Diesel. Also any suggestions on spare parts I should...
Hi:
Part number for the ground output terminal is MIL 039046, list price is $24.34.
For the Big Blue need to specify what engine/model does your machine has or serial number.
Aug 07, 2011 | Miller Trailblazer 302 Welder Generator...
I have a miller wildcat welding/ generator and the problem is that when I start the generator, it runs for a few minutes and then automatically shuts off. Whats the problem?
Hi:
The most common problem is the oil pressure switch. First make sure your machine has the oil up to the level line. If oil level is ok, then order the oil pressure switch and change it. If neither of these two actions cure the problem then send it in to be inspected by an authorized service mechanic.
Good luck
Aug 06, 2011 | Howard Miller Miller Wildcat 200 Welder ...
What does the code on my miller trailblazer 302,004 mean?
Hi:
That's not a code, 004 means the working hours left before the next oil change.
The display always start at 100 and count down all the way to zero.
If you don't change the oil and reset the count down you will start seeing negative numbers, meaning that oil change is due.
To reset the counter once you change the oil do the following:
Cycle engine control switch from the Run/Idle to Run position 3 times.
If this was useful to you, please vote. Thank you..
Mar 23, 2011 | Miller Trailblazer 302 Welder Generator...
Field wiring taps - wire 480 or 208 3 phase need schematic
Hi:
Follow the link for the trailblazer owner's manual, check section 10 for wiring schematic.
http://www.millerwelds.com/om/o4426ab_mil.pdf
If this was useful to you please vote. Thank you!
Feb 24, 2011 | Miller Trailblazer 302 Welder Generator...
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
1,219 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
