We have a cast iron soild fuel fire, when I first start the fire i use paper and kinderling. Once the fire starts it builds and will let smoke back in to the room. When the coals have taken the smoke draws up the chimney. I have had the chimney swept and we are still having this issue. I use premium coal. Do you have any suggestions on how i can cure this? Many thanks Michael
  • 3 Answers
You can only cure that by killing everyone in your house and cuiside
Posted on Sep 06, 2010
Smoke comes out of draft vent and everywhere when starting a fire
Ugh, my husband does this... You have to start the fire so that it does burn hot enough to force the smoke up the chimney (and, yes, make sure the chimney valve is open!). To do this, keep building the fire in baby steps: light with balled up paper beneath a "teepee" of kindling and keep the door open. Once enough kindling is burning, add a couple pieces of larger wood (make sure all is very dry, especially to start) and start closing the door, but make sure the vent is open all the way. Once the wood is burning, add a couple more larger pieces and begin closing the vent - a little at a time, checking every few minutes. No, you don't have to stare at it the whole time, but keep checking. After awhile, you can fill the stove with very large pieces of wood and have the vent closed far enough to lower the flames to very small - but not to smothering totally. This is where the heat really starts and your room gets warm!
Mar 06, 2015 | Home
2010 Chevy silverado starts hard and puffs smoke when cold
Black smoke is too much fuel. My guess would be that there is an injector that is stuck open draining the pressurized fuel into a cylinder or several cylinders. And that is a considerable amount of fuel. And it would account for the hard start because there isn't any fuel being pumped into the other injectors until the pump builds the pressure back up.
Apr 19, 2014 | 2010 Chevrolet Silverado 1500
How do I clean my cast iron skillet?
for some people, a "Visual" is preferred, over a good lesson provided you like to read, btw - thank you Aiden,...
So, if that is you, a preferred Visual learner, then watch this...
May 01, 2013 | Home
How should I store my cast iron skillet?
You should store it without the lid. If you leave the lid on then it is more likelt to rust. Some people even put a paper towel inside to protect against moisture. I leave a paper towel in all my pans.
Jan 16, 2013 | Home
Trouble starting, blows smoke, high revs, fuel leak out of exhaust.
first push starting it was bad. sounds like a stuck exhaust valve. and I think you had a dead ignition coil causing 1 cylinder not to fire,and it was fill with gas ,and then you forcing it to start did more damage
Nov 07, 2012 | 1992 Mitsubishi Pajero
OVER FUELLING ON VW POLO 1.6i. CAR STARTS ONCE HOT DOES NOT START
Backfire means timing is off and unburnt fuel mixture explodes either from compression or a hot exhaust system. Black smoke could mean the fuel mixture is too rich. A metering component is not functioning and sending wrong data correcting the air/fuel ratio.
May 31, 2010 | 1998 Volkswagen Golf
Im having issues when i try to start mygrand????
This somewhat sounds like a fuel concern.You can crank on it and come back again and it'll fire back up.It might be just taking an elongated time to build up fuel pressure due to a failing pump and once it does build up it fires.An easy way to check this is to go purchase a fuel rail pressure gauge and attach it to the rail, make sure al connections are tight, then crank on the vehicle when it's cold and record down your fuel spec from the gauge.Then do it once again, and record your spec down.If your fuel pump is failing the pressure will either be well below spec or it will be below for the first reading, and then higher on the second reading.Hope I could help!!!
Dec 24, 2009 | 2000 Jeep Grand Cherokee
My napolean woodstove has smoke coming from the ash box when I start a fire.It seems to come out of the fresh air damper slider.After the fire is well started it goes away.What could be causing this....
That is usually caused by lack of draft. You may have a partial blockage in your vent pipe or somewhere going to it. Once the heat builds up the draft increases and the smoke is exhausted. Good luck...Lee
Dec 05, 2009 | Napoleon Auburn Pellet Stove Heater
I have a 8 HP Cast Iron line engine in a John Deere Mower, When it gets hot , it begins to mis fire and back-fire, with loss of power, any ideas?
Try enriching the carburator when it gets hot it leans out the fuel mix also try some fuel stablizer or a gas octane booster. Make sure timing is ok and make sure that the govenor is not bound up.
Aug 25, 2009 | Garden
94 COUGAR GETTING TOO MUCH FUEL WONT START
my guess would be a defective fuel pressure regulator, not 100% but i have seen that before ,usually a bad regulator will usually produce a rich (gas) smell and or very white thick exhaust smoke(raw unburned gas),almost the same appearance as smoke from a blown headgasket, and also usually if you hold the thottle to the floor,and crank it for several secs it sould start,if not another alteritive to getting it to start(as to check for white smoke) is to pull the fuel pump relay to stop fuel flow long enough to get it to fire,once it does replace fuel relay,and crank holding it to floor tiil it starts,hopefully this will help you ,good luck
Dec 12, 2008 | Mercury Cougar Cars & Trucks
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
