Question about Maytag Refrigerators
I've checked door seal for leaks, etc; made sure vents in freezer section aren't blocked. Freezer section still gets ice stalactites very quickly. Its possible the defrost cycle isn't working. How do I check that? If the drain tube is blocked, how can I clear it?
  • 50 Answers
You can clear the drain tube by gently reaming with a wire hanger.
Blockage won't cause it to freeze up so quickly though. Check the thermostat setting? Otherwise it is very likely that the thermostat is not deactivating when it should. This would require replacement of the thermostat.
Posted on Sep 06, 2010
LG refrigerator Ice build up in the bottom freezer
Check the seal in the freezer, if it is leaking outside moisture can get in as well as cause things to defrost near the leak. Also make sure the contents aren't blocking the door to where the seal is leaking. If this is all OK then perhaps the fan units fan is not pulling the moisture out. It does tend to build up in most freezers a bit anyway. also
May 11, 2014 | LG LFD22860 Stainless Steel Bottom Freezer...
Freezer working, refrigerator not
Hello Georgia Peterson - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means that the unit has a faulty compressor or a sealed system leak. Also there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
Jan 13, 2013 | Frigidaire FRT21H8 Top Freezer...
What would cause my frigidaire refrigerator to not get cool p/n 240508000
Hello - If I may suggest, as it is a Top Mount; there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means the unit may have a faulty compressor or a sealed system leak. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
Nov 04, 2012 | Refrigerators
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
Whirlpool 220L FF is not cooling neither on the refrigerator sector and very less cooling in freezer section. No air coming out from the vent section located in freezer compartment
Hi
Over time debris, ice or food particles can get stuck or lodged into the vents. If the vents are blocked cold air is unable to properly flow through the unit. Cleaning the vents will cause the cool air to circulate throughout the unit once more. Check the vent to be sure there is no ice that needs to be melted. Defrosting the unit with a blow dryer for faster results may solve your problem. Another place to check is the refrigerator seals. Seals are what keep the appliances door closed. Cracks in the seal will result in a loss of cool air. This causes the unit to run continuously, which can ultimately lead the complete unit to shut down. It can also be the reason the temperature has increased. It is also a possibility that your refrigerator is not cold because of the evaporator fan. The evaporator is activated by the door switch, which comes on when the door opens. If the switch is not working properly it will not turn on the evaporator fan.
Please check this link to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 02, 2011 | Refrigerators
FREEZER FREEZERS BUT THE REFIGERATOR WONT GET COLD
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If the vents and air flow paths in the refrigerator are proper, then check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 01, 2011 | Whirlpool Refrigerators
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
My walk-in freezer is developing stilagtights (ice castles) on the floor and cieling in front of the evaporator coil.MY drain pan is not plugged when I pour water down it.
You should check for air leaks around the door gasket or any other openings in the compartment such as where pipes or wiring is going through the wall. It sounds like a moisture problem from moisture being drawn into the compartment pass door gaskets or access holes.
Mar 07, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Ice & water dripping in refrigerator
ok your defrost drain is frozen take the back panel off in the freezer section under the coils you will see a silver pan if its frozen it will be a block of ice you have to remove the ice then make sure the drain and tube are clear all the way to the pan at the bottom you should see the plastic tube on the back of the unit in the center over time algae can grow in the tube blocking it drying the unit will help but soon as it defrosts the tube fill up again and the problem reoccurs you kinda got to snake it out so to speak.the best way to deal with it is to go to lowes or home depot and get a eurka 302 enviro hand held steamer an investment but a great product to have around the house cost about 40 bucks but 1000s of uses
Feb 13, 2008 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
