Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Frigidaire freezer, only 2 bottom slelfs freeze
Its only 6 yrs old and only the top 2 shelfs are cold and bottom 2 freeze. nothing needs cleaned underneath or in the back, should i junk it? The warranty is up except for the compressor but it doesn't seem like the problem is with the compressor.
  • 828 Answers
If your freezer is six years old the compressor warranty is also over. Sounds as though the system has lost its refrigerant charge. A refrigerant leak in these smaller units is difficult to locate and somewhat expensive to repair. Your choice.
Posted on May 16, 2008
Our freezer sat in the garage unused and unplugged for about a year. Now we are ready to use it so we plugged it in. Its been on about a week now and its still not getting cold inside. Actually I...
something easy to try is to clean the evap. usually on the bottom. warm soap and water, or compressed air usually does the trick. it's the easiest thing to try.
Aug 21, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Not freezing on top shelf of door
try to replace the Styrofoam cup then put on the top.. if the same happens.or it will be frozen it means styrofaom is .................................. then use another...
Jun 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
May 19, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Top shelf not freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 27, 2010 | Freezers
Frost build up on 1 shelf then 2 shelf and so on - hard freeze on top soft freeze on bottom upright 7.5 freezer
door gasket sealing properly kids hanging with door open? condenser clean? if its a forced air condenser if it is a static freon problem. Tom
Jun 16, 2009 | Kenmore 7.5 cu. ft. Upright Freezer 28702
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
222 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
