Question about Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher
Stuck in wash cycle... timer bad? - Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher
    Problem Solver:
  • 40 Answers
Possibly the booster is not reaching proper temperature.
Posted on Feb 13, 2014
Machine is not moving through the cycles
It sounds like the motor in the timer is bad. This may require replacing the whole timer or just the timer motor in some cases. I hope this helps.
Mar 20, 2010 | Whirlpool Washing Machines
Timer only works on heavy cycle not on normal model #11024632300
Could be a bad timer or loose contacts.
Unplug the washer.
Open the control console.
Remove the wire harness connector from the timer and re-insert it.
Also advance your timer manually 360 degrees around several times. This can cause stuck contacts to work correctly.
If this does not correct your problem you will need a new timer.
Feb 14, 2010 | Kenmore 24632 Top Load Washer
Starts, but does not move on through cycles
check your lid switch may be broken. or could be your timer does it stop and not advance? if it gets stuck you more than likey have a broken lid switch. but if it gets stuck in one cycle and keeps washing and washing and washing you more have a bad timer.
Jan 05, 2010 | Roper RAB2121KW Top Load Washer
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
Repeats cycles
this sounds like you have a bad timer. you can get a new one and quite often you can find a place where they sell rebuilt timers for quite a bit less.
Nov 12, 2009 | Washing Machines
Doesnt go through programs
sounds like you have a bad timer or lid switch. does it finish a cycle but not advance or does it just keep washing or does it wash then stop and get stuck? if it just keeps doing one cycle like wash wash wash you would have a bad timer. if it washes then stops and gets stuck you have a bad lid switch. But then again if you had a bad lid switch it would never spin. What is the brand name of this washer?
Jun 10, 2009 | Washing Machines
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
Aug 05, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Maytag Washing Machine Problem
yes it does sound like a bad timer
Nov 25, 2007 | Washing Machines
Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher Logo
75 people viewed this question
Top Moyer Diebel Dishwashers Experts
Owen Barnes
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
