Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
My freezer's temperature alarm is on, and it is about 38 degrees inside the door. It seals fine as far as I can tell.
  • craig_and212 Sep 06, 2010
    Thanks greyray. The motor is running, but I am not proficient with elec. at all. I found a buildup of ice on the floor of the freezer. The drain hole in the back was frozen over. Itook everything out and defrosted it, and turned it back on. I'm not sure if that was the problem or not. time will tell.
  • 50 Answers
Is the motor running?
If not the problem is most likely the thermostat.
If you are proficient with electricity, you could try bridge it and see if that works. If so, you have located the problem.
Posted on Sep 06, 2010
Upright freezer door was left ajar. The alarm keeps sounding, can you tell me where the reset button is located.
Hello Deena;
My name is Peter. I am a retired field service refrigeration technician.
There is no reset for the alarm. The alarm goes off when you are not maintaining temperature.
During the time the door was ajar, warm air got into the freezer either icing up and locking the cooling fan or forming a block of ice on the cooling coils (Restricting cooling air flow.)
The best thing you can do, unless you want a $300.00 plus service call to defrost everything, is to turn power off to the freezer. Open the freezer door. Have plenty of old towels to soak up the water in the bottom of the freezer as it defrost.
You did not provide a model number which is located on the inside wall of the freezer. Every 8-10 hours your freezer will completely shout down for 20-30 minutes where only the light works and the defrost heater turns on. The ice build up is too much for the defrost heater to handle.
In some freezers the defrost mode is in the control board, in others it is a separate component that you can repeat trip using a flat head screw drive.
Jan 26, 2016 | Freezers
Door was not sealed tightly for about a day resulting in some frost inside freezer. Door appears to be closed but door ajar light is still lite and alarm is still beeping. What do I need to check?
The door seal has a magnetic property to it. Until the freezer gets to a certain degree the magnetic porperties of the door seal dont react properly. Make sure the door seal is properly adjusted. If the door was left open it could have semi warped the door. This gets corrected when temp drops to correct temp. Reset freezer by unplugging and waiting for a few minutes. If problem persist contact appliance technician.
If you have any more questions you can comment me back.
Jul 28, 2011 | Frigidaire Freezers
My Miele freezer the alarm bell is bleeping but it is not defrosting what could be the problem please.
The beeping could be a low temperature warning. Check to make sure the temperature is staying cold enough and then check the door seal. Use a store bot fridge/freezer thermometer. Use a dollar bill to check seal. If you close door on the bill it should hold the bill tight but still let you pull it out. If it is loose then you need to adjust the door to fit tighter.
Sep 21, 2010 | Miele Freezers
Alarm
The alarm usually is telling you that the temperature inside the freezer is not low enough. Check the door seals with dollar bill. Shut the door on the bill and try to move it. Try all around the door. The bill should resist being pulled out. If you can't pull it out the door is too tight. If it comes out easily you have an air leak. you can adjust a freezer door by loosening the hinges, pushing the door into place and re-tightening the hinge.
Sep 18, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Freezer alarm
Upright freezer door was ajar, alarm went off. Where is the reset button? Product is Frigidare.
Jun 02, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
415 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
