Question about Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready LCD Television
LCD Panel CHange
Good morning,
I have an LCD TV Sharp 32" 720 pp and the LCD Panel is apparently damaged. Is it possible to have it changed and do you happen to know if the price is worth the change vice buying a new set?
Thanks for your help.
  • juisen May 13, 2008
    My 4 yo boy whipped a fishing pole onto the screen. After that only 4/5 of the whole panel are useful. The rest comes as a colored streak all the way down from the top and spamming about 6 inches from the left to the right.
    Thanks for the help.
  • juisen May 14, 2008
    Thank you very much. It surely helps a lot.
    Genius:
  • 1,224 Answers
I found several sites with replacement parts relativaley cheap there are places out there that have what you need
i saw panels 120 to 185 depends on model
Posted on May 13, 2008
  • 4,234 Answers
Typically if the panel requires changing, it is less expensive to replace the entire unit. Why do you think the panel is bad? Unless it has been dropped, it is rare for the panel to fail.
Dan
  • ABRsvcs May 14, 2008
    FYI - THe pat number for the LCD panel is: DUNCTKC793FE22 and costs $331,25 with a dud return of $120.00
    This means that once the opanel is returned to the source, you will be refunded $120.
    Hope this helps. (I assumed that the model is LC32GA5U)
    Dan
What is causing vertical colored lines on the left 25% of my Sharp Aquos display?
Bad TCON board or Damaged screen. You can try and replace the TCON "Timing Control Board" and see if that helps. Replacing the Screen itself is very expensive and normally about half of what the unit cost new. Here is a video to give you a clue on how to do so, it is pretty easy when you know which board to replace.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Jan 01, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Is it possible to get a 46 inch panel for a sharp
If the actual LCD panel is cracked, you don't want to even bother looking for a replacement. It would be either the same cost or more expensive to replace the LCD panel than to buy a brand new one. The other issue is if you are going to attempt to do it yourself, there is a chance that you might inadvertently damage something in the process so you would be out the money you spent on the LCD panel and you would still need to buy a new one. These are called consumer models for a reason. Mass production drops the price of the unit, but replacement parts outside of that mass production sometimes are as expensive if not more expensive than a brand new whole unit and are a lot of time VERY hard to find. LCD's are disposable once the actual panel is damaged.
Nov 06, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I have a Sharp Aquos TV that only displays a colorful grid.
your t-con board is failing call a tech to install a new one
Sep 19, 2009 | Sharp LC-60C46U LCD TV
Sharp Aquos Resolution
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
Jun 11, 2009 | Sharp LC-32D64U LCD TV
Is it possible to replace a broken lcd screen on the Sharp LC-42D64U or is it just toast?
Sorry to say, it's pretty much toast. The screen is most of the cost of an LCD TV, so if it gets physically damaged you're better off replacing the set.
May 08, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Damaged the LCD - Sharp 46 in. LCD Full HD Television, AQUOS®
Yes it is possible to replace the panel. I would suspect that it is cost prohibitive however. I am willing to state that the cost of the panel will be close to if not more than the cost to replace the TV.
Sorry about the bad news.
Dan
Feb 02, 2009 | Mitsubishi VS-5076 50" Rear Projection...
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready LCD Television Logo
307 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
