Question about Motorola Mobility i560 Cellular Phone
I560 cell phone
My phone never used too do this until latley. the problem is every time I bump the direct connect button it chirps the last person that I had connected too. Could you tell me how to keep this from happening anymore? My boss tells me to put my keypad in lock mode but then you have to unlock it in order to use the phone. Thats a pain! Can you help me to get my phone back too its old self again? Thanks for your help.
    Genius:
  • 1,224 Answers
You can change your keys settings around and say turn that button into like the phone book key in settings and put the direct connect button inside on the closed part
Posted on May 13, 2008
Does anyone have an installation manual for an Autopage RS-610 Plus? I need to program a new remote.
Note: This system can keep up to 4 remote transmitter in its memory. If
more than 4 transmitters programmed, the system will keep only the last
4 transmitters.
PROGRAMMING THE REMOTE TRANSMITTER
Enter:
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in the 'ON'
position. Within 15 seconds.
2. Push the Valet switch 2 times (Holding in on the 2nd push) until you
hear a long chirp. The transmitter is ready to program.
Program:
1. Press any button on transmitter until the siren responds with a
confirming chirp the first transmitter is now programmed.
2. Press button on the second transmitter until the siren responds with a
confirming chirp, the second transmitter is now programmed.
3. Apply the same procedure to program 3rd and 4th .
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. A 3 long
chirps & 3 parking light flashes to confirm exit.
Apr 12, 2017 | Autopage Vehicle Parts & Accessories
I560 Cell Phone: I need the subsidy unlock code for my motorla i560...
There can be many ways to Unlock your phone.
As far as i know unlocking by codes is the simple and safest way.unlock using software delete some information in memory i unlock my phone using codes ,i got codes from http://www.theunlockarena.com/motorola-i560/rs13wp9/
I used codes to unlock my cell phone. i had my unlock code and my phone was unlocked.
May 17, 2010 | Motorola Mobility i560 Cellular Phone
How to change voice message on i560
  1. Access Voicemail
  2. You will be prompted to press:
    1 To Listen to new messages, or
    2 To Record and send a message.
    You will not be prompted to set your Greeting at this point - press 3 to Access Phone Manager.
  3. Press 1 for Personal Options.
  4. Press 3 to Record a Personal Greeting.
  5. To record the Busy Greeting (when you are engaged) press 1 or to record the Standard Greeting (all other occasions) press 2.
    Your existing Greeting will be played to you.
  6. Follow prompts to record a new Greeting:
    To Start press 2
    To Stop press 2
    To Save press 5
    To Review press 6
    To Delete press 4
    To Exit press * until system says "Thank you for calling".
Let me know if this will help
Nov 30, 2009 | Motorola Mobility i560 Cellular Phone
When putting the phone in the clip sometimes it will redial the last number called. I don't see any buttons on the outside that would redial. I know the right button on the right top brings back the last...
The right button on the right top that brings back the last dialled number may be the culprit. Check to see if a long press on this button redials the last number. If so, then the clip is pressing it too long. Can you avoid using the clip or modify the clip so as not to press this button.
Nov 09, 2009 | Motorola Mobility i560 Cellular Phone
SIM id on my Motorola i560 cell phone
follow this sequence. press #, then star, then menu and then your right arrow on your phone. in sequence and in that order.then scroll down 7 places and you will see IMEI/SIM ID/SN hit your ok button and you will see your sim Id
Jan 22, 2009 | Motorola Mobility i560 Cellular Phone
I need to reset my phone
When you say it is restricted do you mean that it is just asking you for a password .. usually the password is the last four numbers in your cell number that should let you reset the phone.
Aug 21, 2008 | Motorola Mobility i560 Cellular Phone
Please help with my i560
you can change your keys settings around and say turn that button into like the phone book key in settings and put the direct connect button inside on the closed part
May 12, 2008 | Motorola Mobility i560 Cellular Phone
I 560
Sounds like the microphone in the handset came loose or went bad. Turn the phone off. Press and hold buttons 1, 2, and 3 while turning phone back on. This puts you in self test mode. Follow instructions on screen until you get to audio loopback test. Put phone to your ear and talk like you normally would. If test fails the mic is bad. Take it in to a service center.
Oct 12, 2007 | Motorola Mobility i560 Cellular Phone
Motorola Mobility i560 Cellular Phone Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
