Question about Casablanca Fan (3232A) Ceiling
My Stealth casablanca fan wobbles like crazy above setting 3. We've had this fan for several years.
4 Suggested Answers
SOURCE: Casablanca Stealth Fan - Unresponsive To Remote
I fixed this myself by upgrading to an Advan Touch unit. Details here: http://www.casablancafanrepair.com/HTMLFiles/ do_it_yourself/ComfortTouchCommonRep/CTToItConvert6-12- 07Web/SM_CTToAdvanConvert_P1.htmI purchased the P-RMM CT to AT Converts Comfort-Touch to Advan-Touch upgrade kit from http://www.fanmanlighting.com/shop/pc/viewPrd.asp? idcategory=56&idproduct=966The fan man was helpful and my parts reached me in 2 days, normal shipping!
Posted on Jan 04, 2010
toolkits
  • 1099 Answers
SOURCE: Casablanca Delta II fan wobbles terribly at high
Use the fan regulator to adjust the speed of the fan, and if it does not adjust the speed, then you have to replace the fan regulator.
Good luck...
Posted on May 31, 2010
  • 57 Answers
SOURCE: Casablanca stealth fan light scrapes against blade surround
There are two probable causes. One, the light housing has been pushed/bent up into the rotating assembly, which is possible if the fan were ever removed from the ceiling and sat on the glass.
If it has never been removed however, the most likely cause is that the Allen Set screw on the flywheel has loosened allowing the flywheel to slip down the motor shaft. It's a purely mechanical problem and if memory serves, to get to the flywheel, you remove the light pan and it's right there. Find the set screw, loosen it enough so that the flywheel is easy to move up and down and raise it up a bit and then cinch it down tight. It's a fairly common problem and for the life of me I cannot understand why Casablanca would not use loctite on that set screw. I mean you pay $500+ for a fan, it should outlast you, right?
Posted on Jun 10, 2010
How do I op beeping of my Casablanca stealth fan Bulb is burnt and I removed he burnt bulb. would not top annoying beeping
Replace the bulb. If you are going crazy while getting a new bulb turn off the breaker for the room. A serious design flaw, I would complain to Casablanca if you have the time.
Oct 05, 2014 | Casablanca Fans Casablanca Contemporary...
Casablanca stealth
Sounds like you need a new receiver.
Jul 19, 2014 | Casablanca Fan 3245A STEALTH® Brushed...
Casablanca stealth fan scraping noise
center of blade bracket mounts scrapping fan housing. Grasp blades and wiggle or shake them to make sure their not cockeyed. Turn it on then to check it.
Apr 13, 2014 | Casablanca Fan Dryers
Only works in third
Probably needs a new receiver. Call Casablanca @ 1-800-715-0393
Dec 14, 2013 | Casablanca Fan 3029818293 Stealth Ceiling...
Casablanca fan-how to replace flywheel?
You'll need a special tool to take it off. Check www.casablancafanco.com for the nearest service center.
May 07, 2013 | Casablanca Fan Stealth 3211T Ceiling
Jun 03, 2010 | Casablanca Fan 3245T Ceiling
Casablanca Delta II fan wobbles terribly at high speed. How can this be fixed?
Good luck...
May 31, 2010 | Casablanca Fan 3245T Ceiling
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
Need a replacement fan speed potentiometer.
Okay -- first off, I don't know where she got that number from, but that's idiotic.
The variable-speed switch will provide different readings depending on where it's turned to. If the switch is busted ("open), it will typically display a reading of 'infinity' on your ohmmeter.
And yes -- the best place to find a replacement is Radio Shack, since Casablanca discontinued them.
HOWEVER---
Casablanca's variable-speed ceiling fans -- specifically the "SlumberQuiet" ones, which were made from circa 1980 or 1981 to the early/mid 1990s when variable-speed was discontinued -- are well-known for breaking down. The problem is almost never the potentiometer (variable-speed dial). Rather, the problem is almost always the resistor which is mounted in the heat-sink inside the fan's motor housing. There are NO replacements left for these -- so Casablanca makes a "variable-speed to 3-speed conversion kit", which will convert your fan to a more normal 3-speed pull-chain (hi-med-low) setup.
I hope that helps! If you have any other questions, please feel free to ask!
Jun 16, 2008 | Casablanca Fan Dryers
Casablanca Fan (3232A) Ceiling Logo
243 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
