TV will not power OFF
Have a Toshiba 27" was working fine but now it will not power off with either the front button nor the remote. The only way we can shut it off is to pull the plug.
Any suggestions? your help would be appreciated if you can reply to
yergel1934@gmail.com
Thanks
Gerry
    Master:
  • 788 Answers
Do the other buttons on the TV (volume, chanell, etc..) work ok? Often the button pad on a TV will be wired in a matrix like a computer keyboard, if one key is stuck then the others might not work.
Posted on May 15, 2008
Toshiba television won't turn on after power flicker
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
Power button does not work on front of TV or on remote.
Try the tv in a different outlet. If the TV still doesn't turn on take it to a repair shop if you have no experience troubleshooting electronics.
Feb 18, 2015 | Toshiba 27A45 27" TV
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
Model 27AF45 Toshiba TV shuts down as soon as it turns on with remote or with the manual on button. was working fine, and one day it just shut off. no lightning or power outage...just died one day.
There is power supply fault inside the TV. it could be any fault up to the E H T circuit. That is the reason the S M P S is shutting down the moment the TV is switched ON.
Do not attempt to repeat. Rectify the fault.
Apr 09, 2010 | Toshiba 27AF45 27" TV
I have a toshiba tv with a broken power button
Generally the power button has to be on first to put the TV in standby mode. If you cant do this no remote can ever work. Remotes are not capable of turning on a set that has no power mechanically turned off. and that is what the master switch does. once that standby light is off it is not live and consuming power and not under the control of a remote anymore
please rate our help++++Y=Thanks for using FIXYA
Sep 25, 2009 | Sharp 27N-S100 27" TV
Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Dec 14, 2008 | Zenith B27A11Z 27" TV
Power button changes channels and volume does not work
bad solder connections. front control panel.
Nov 23, 2008 | Philips 27PT543S 27" TV
Audio trouble with my tv
use your remote . manually fine tune your tv.
May 05, 2008 | Toshiba 27A33 27" TV
Not able to get to tv-video on Toshiba 27A45
For TV video switching change program (-) button till you get 1 or 0. After 1 or 0 again press program (-) button you get video mode. Or try any other option in menu features to change video mode. I hope the above information is helpful to you.
Sep 03, 2007 | Toshiba 27A45 27" TV
TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
May 02, 2007 | Toshiba 27AF41 27" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
