Switch On
your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are
facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot your problem should be resolved.
Switch On
'System Restore'
click Next
facing the issue, try to select a date prior to that date. In your case try to select a date as old as possible but do not select the first date.
Now, Click on Next and System Restore will start and windows will take a reboot.
Switch On
'System Restore'
click Next
1) If you are using Windows XP the follow the steps given below:
Switch ON the PC, boot the PC
in 'Safe Mode' by continuously tapping F8 button after you switch On until you
get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
'System Restore'
click Next
facing the issue, try to select a date prior to that date. The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date. 1. Open the
Start Menu. A) Click on All
Programs, Accessories, System Tools, and System Restore. 2. Open the Control Panel (All Items View). A) Click on the Recovery icon. A 'System Restore' window will appear. Here you will have to check
"Restore computer to an earlier time' A) Click on the Next button Now you will find a window with Dates, Description and Type, Note: It is better if you could remember from which date you are
reboot.
2) If you are using Windows 7 then follow the steps given below:
B) Click on the Open System
Restore button.
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
The
detail of that particular date should show "System Checkpoint" and
reboot.
