Question about Maytag Dishwashers
We have a Maytag MDW700EDWG washing machine and it has stopped working. The display window is showing F2 and will not go to the time lenght of any program. I am unable to switch it off at the Start button. It is making a noise as if it is trying to do something - but then stops. I have cleaned the filters, checked water supply but still have F2 showing. Please can you shead any light or let me knoiw what to do Many thanks Emma
Is it the salt reservoir that is empty?
Did you solve it already...mine has the exact same issue now
Posted on Mar 06, 2011
I have a Maytag MAH-24 Washing Machine showing a 5E error code
You will have to contact Maytag and speak to their service dept and give them your model number. Ask them what a 5E eror is and when you call for service, tell the repair facility what Maytag told you. That will next to eliminate labor cost for Diagnostic.
Apr 17, 2012 | Maytag Washing Machines
My washer shows an "ld" code after stopping in the
I have looked and looked and can't find an error code "ID" for any Maytag washing machine! Are you sure that is what is being displayed.
Jun 05, 2011 | Maytag Washing Machines
Our Front loading High Efficiency Washing Machine (Maytag) had a F2 code flashing and I can't locate the manual after I moved. Could you help diagnose the problem?
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display sud and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 02, 2011 | Maytag MAH8700A Front Load Washer
Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Jan 20, 2010 | Washing Machines
During the wash cycle the machine comes to a stop and beeps. display shows "F2" ??? I then have to pause it then turn the machine back on for it to continue.
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Jul 20, 2009 | Washing Machines
Maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dishwashers Logo
96 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
