Question about Philips Senseo HD7832 Coffee Maker
How can I reset my Senseo coffee maker? All of a sudden it stopped working. Thanks.
  • 5 Answers
SOURCE: stuck senseo maker
Your machine has been locked because there is too much pressure inside the machine. Unplug it for about 24 hours and leave it with the lever up. After that it should come open. Carefully clean out the tiny nozzles to make sure there isn't any loose coffee hanging out in there. This happens if you make your own pods. Just be grateful that it didn't explode all over your kitchen!
Posted on Mar 05, 2008
  • 5 Answers
SOURCE: Senseo coffee maker
There isn't a way to adjust it. The senseo is calibrated to make either a 4oz or 8oz cup. Unfortunately, we are so used to buying mugs at the store that are MUCH bigger than this!
SOURCE: GE 169164 coffee maker problem
I bought the GE 169164 coffee maker from Walmart, I also got the cleaning problem, I found and downloaded the manual from this link http://www.gehousewares.com/Browse_Product.aspx?category_id=12 Automatic clean function is explained in page 11. Fill reservoir with water, press cleaning light which is also a button for 3 seconds until it flashes and wait to cleaning to finish.
Posted on Sep 30, 2008
CHA55Y
  • 13 Answers
SOURCE: My Starbucks Grand Barrista 12 cup coffee maker stopped working.
from what i can see they have pumpo issues..... try your warranty although i guess that'd be long gone after your many "years" of ownership.... anyway, get an expresso machine, they produce much better coffee by far :) Goodluck, CHA55Y....
Posted on Jun 14, 2009
SOURCE: My senseo coffeemaker has stopped pumping hot
When was the last time you clean it with vinegar? Run vinegar through it and you will see hard water scales that were built on the heater. Coffee makers should be clean out every month then with 2 rinse cycles after that.
Posted on Jan 24, 2010
Philips Senseo HD7810 /40 stops midway brewing
This lookes like a problem I experienced with another model of the Senseo. The problem here was the 470nF X-capacitor in the capacitive power supply. (230VAC models) Try replacing.
Aug 15, 2013 | Philips Senseo HD-7810 Coffee Maker
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
The machine starts then suddenly gives a loud pop then the seal is broken and coffee LEAKS out
That's one for the repair shop, really. The seal is usually bent inwards so it can withstand the pressure of the hot water, but once it's able to flex out it needs to be replaced.
Oct 19, 2010 | Philips Senseo HD-7810 Coffee Maker
Senseo coffee maker
http://www.eserviceinfo.com/downloadsm/19109/Philips_Senseo%20HD7810/10.html
OK above is a service manual, this is what the techs use to fix, it. Use the exploded diagram,and troubleshooting guide, and you will no doubt sort it very quickly.
http://www.devicemanuals.com/guide/Home%20Appliance/Philips/Philips-SENSEO-Coffee-Maker-HD7810-75-54-User's-TXpBNE1qTT.html
Download the user manual above.
Apr 03, 2010 | Philips Senseo HD-7810 Coffee Maker
My senseo coffeemaker has stopped pumping hot water through the coffee pods. What do I do to fix it?
Jan 24, 2010 | Philips Senseo HD-7810 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Hello, I have a Senseo HD7842/00 (Alu) coffee machine, which still physically works, but for some reason none of the lights come on any more. The small LCD screen is no longer back lit (used to light up...
Connections on circuit board are no good.
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Nov 26, 2008 | Philips Senseo HD-7810 Coffee Maker
Replacement seals for Senseo Coffee machine
If no good,
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo coffee problem
The pod holder has an O ring to seal the black plastic disc in,if it is not sealed you will end up with more volume and a weaker coffee without the foam,either knock the disc out and try and seat the O ring and then knock it back in or buy a new pod holder,I had this same problem
Nov 30, 2007 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD7832 Coffee Maker Logo
1,552 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
