You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
It sounds like something got switched in the reassembly. It happens. Here is the service manual to try and figure it out. Let me know if that helps, or you need some more help. Good luck. Service Manual McCulloch MS1432
Your chain saw is a manually oiled model which means YOU have to pump
it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by
the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent
you the link to the owner manual and gave you a diagram. Click here
Use model number 315.34020 which is the same saw w/o power sharp. In fact the 34030 model is mentioned in this manual. I haven't found anything relating to the 34030 model specifically. Oregon products is able to cross reference the saw and find parts for it (less the power sharp feature.)
if you are talking about the gas or oil tubes then yes they can, but what a job it is to do . if i have to do it again, i am going to send it to a shop. you almost have to disassemble the whole thing.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here: Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered (I did not get any hits). http://www.arboristsite.com/showthread.php?t=72322 HTH Lou
Here is the owner's manual for the M30016AW... http://12.153.20.74/manuals/113005-01G.PDF. Here is also the instructions on the installation for the chain that goes on the your saw ... http://12.153.20.74/manuals/113556-01A.pdf. If you are need of a part you can conatct Master Parts at 800-446-1446, they can also help you. I hope this helps!
I suggest going to the Mfg. Site, and Looking at what they Have, and sending them a Request if you can't find what your looking for. Contact: http://www.mccullochpower.com/node3828.aspx?nid=81500
