Question about Linksys Wireless-G Broadband Router
I need a password for the setup of this wireless router
    President:
  • 1,118 Answers
Try entering 'admin' (without the quotes) in the 'Password' field only, thus leaving the 'User name' field empty.
Hope it works for you.
Regards, Carlos
Posted on Sep 06, 2010
    President:
  • 1,851 Answers
The factory password for Linksys is "admin", "1234" or none. In case that you have already change this, you have to reset the router in order to come back to defaults.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
  • 76 Answers
Older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Forgot my password linksys n600
Are you trying to connect to the wireless network?
Or you are trying to open router setup page?
Please explain in details.
If you forgot the wireless password then it can be found on router setup page. You need to open the router setup page and find the wireless network password.
Check this link to find wireless network password
If you are not sure about router password then you need to reset the router and reconfigure it.
Thanks
Jul 20, 2014 | Computers & Internet
Requiring password
If your wireless access suddenly requires a password, one of two things has happened...
either you are inadvertently trying to connect to a neighbor's wireless router, or someone has modified your router.
If you are certain it is your router you are attempting to connect to, and it is requiring a password you did not setup, your best bet is to perform a hard reset. There should be a reset button on the back of your router. You should press and hold this button for a few seconds. This will clear all setup information and return the router to factory setup.
In order to setup your router from this point, you will need to connect directly to the router, perform whatever setup options you prefer, and then you should be able to connect wirelessly.
It is highly recommended that you setup a password for wireless access. It is also recommended you change the admin password to prevent someone else from making unwanted modifications.
Jun 18, 2013 | NetGear N600 Wireless Dual Band Router
Need passwword for belkin wireless router
By default, Belkin routers do not have a password,just click on Submit to log in..But you should check check your Belkin router setup documents.
If you forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
Sep 11, 2012 | Belkin (F5D7230-4) Router (587009)
Changing my password
Which password you trying to change?
Are you trying to change wireless network password?
You will need to open the setup page of the router and check the wireless settings.
You will find the wireless network password. Change it.
Use wired computer to open the setup page of the router.
Do not use wireless computer to change wireless settings on the router.
See how to open setup page of the router.
May 20, 2012 | D-Link AirPlusG DI-524UP Wireless Router
WEP key
Hello.
Do you need the wireless password or the router login password?
If you need
wireless password(security key like WEP or WPA) or you would like to setup wireless security for your Netgear router, access the router setup page by typing http://www.routerlogin.net or http://192.168.1.1(sometimes it's http://192.168.0.1) in the address field of your browser and then press Enter.
Enter
admin for the router user name and your password (or the default, password).
This image is the login window to access the router's setup page.
After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the Wireless Key(For WEP you need Key 1,2,3 or 4 whichever is selected... For WPA you need passphrase) or you can setup wireless security from there if you haven't done so.
This image is the router's setup page and this is where you can configure the router and check some settings like Wireless security or password.
**If by chance you are unable to access the router's login or setup page by using the default username &password(admin, password) and you totally have forgotten it, you need to reset the router to factory or default settings then you have to setup the router again.
**To reset the router to default settings:1. Unplug all the cables attached to it except the power cord.
- Make sure the router is plugged into the power outlet, then hold down the reset button at the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
2. Once the lights are stable, connect 1 computer or laptop directly to the back of the router(Ethernet/LAN ports usually they are labelled by numbers and have the same color, just pick one). If you pick number 1, check the corresponding light indicator at the front panel of the router, make sure light 1 is also lit up if not choose another port at the back of the router.3. Setup and configure the router again.
~~Hope this helps~~
Nov 28, 2011 | NetGear Computers & Internet
Get password
Hello.
If you need
wireless password(security key like WEP or WPA) or you would like to setup wireless security for your Netgear router, access the router setup page by typing http://192.168.0.1) in the address field of your browser and then press Enter.
Enter
This image is a sample of the login window to access the router's setup page.
After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the Wireless Key(usually indicated as "passphrase") or you can setup wireless security from there if you haven't done so.
1. Unplug all the cables attached to it except the power cord. - Make sure the router is plugged into the power outlet, then hold down the reset button at the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
~~Hope this helps~~
Nov 27, 2011 | NetGear DG834G Router
I do not remember the password for my wireless router. How can i get it?
Hello.
If you need wireless password(security key like WEP or WPA) or you would like to setup wireless security for your Netgear router, access the router setup page by typing http://www.routerlogin.net or 192.168.1.1(sometimes it's 192.168.0.1) in the address field of your browser and then press Enter.
Enter admin for the router user name and your password (or the default, password).
This image is the login window to access the router's setup page.11_27_2011_1_31_58_am.png
**To reset the router to default settings:1. Unplug all the cables attached to it except the power cord. - Make sure the router is plugged into the power outlet, then hold down the reset button at the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
Hope this helps. Have a nice day.
Nov 27, 2011 | NetGear Computers & Internet
Need password for wireless roter
If you need the login password for the router's setup page, the default username: admin, password: password.
If you need the wireless key or password, you need to access the router's setup page by typinghttp://www.routerlogin.net or 192.168.1.1 in the address field of your browser(IE or Chrome). On the login use the default username and password(admin, password).
After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the WEP or you can setup wireless security from there if you haven't done so.
**If by chance you are unable to access the router's login or setup page, you will have to reset the router to factory settings by holding the reset button on the back of the router using a paper clip or a pen for 30 seconds while the router is plugged in to the power outlet. You will then be able to access the router's setup page using the default username and password.
Hope this helps.
Oct 16, 2011 | NetGear WNR2000 Wireless Router
Reverted to factory default, typed in router name and wap password, but cannot acces, it goes to dlink
you need to reconfigure the wireless settings since you reset your router to factory defaults.
login to your router with admin/admin as the login/password
click on wireless settings and enable wireless security mode to wpa and type in the wireless password you wish to setup.
all wireless devices will need to be setup to your new router settings.
May 22, 2011 | D-Link DIR-615 Wireless Router
(F5D8231-4) Wireless Router (F5D82314): need password to setup...
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
May 07, 2010 | Belkin (F5D8231-4) Wireless Router...
Linksys Wireless-G Broadband Router Logo
104 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
