Question about Kenmore 53542 / 53544 Side by Side Refrigerator
First Refridgerator part got warm and fan part where cold air comes out was completely iced over. We shut it off and let it defrost completely and dried it out. Everything is runnig great but now the freezer is getting ice under the bottom drawer and if not contrled it leaks onto the floor.
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
Refrigerator is warm and will not cool food and the freezer is iced up
Theres the problem an iced up freezer, the cold for the food compartment comes via a fan in the freezer, no flow, no cold, firstly defrost it completely, check fans are working, if they are ok then it's probably your defrost hester element.
Nov 22, 2013 | Refrigerators
Freezer working, refridgerator not, what could it be?
freezer is where the cold comes from . then the fans move the cold to the fresh food area .. ck for ice build up in back of freezer and make sure the fan inside is working .. clean the coisl under neath . and ck fan . if iced coil in freezer . ck the heater and terminator .. if ok replace the defrost control .. hope this helped mm feed back pls .
Jul 10, 2011 | Jenn-Air Refrigerators
Freezer side works fine but the fridge side seems to be getting warmer even with temp dial set all the way cold. No warm air flow from bottom. is condenser bad?
you hae an issue with the defrost cycle in behind the panel in the freezer how the defrost system works Here is what's happening when you have a malfunction in the defrost system.
  • Air cannot circulate from the freezer(where the cold happens basically) to the fresh food section.
  • Your refrigerator will run constantly to try to cool the fresh food section. This will develop a new set of problems with your refrigerator. More on that later....
  • Excess frost builds up within the coils inside the freezer. This is what is blocking the air flow to the fresh food section
  • Usually you will notice the icemaker will stop making ice. Poor air flow and not quite cold enough temperatures in the freezer cause this
  • Water will not come through the dispenser on the door. Cold air settles, the water resovoir will freeze.
  • Compressor may overheat and shut off. This is when you hear, click, click, click. Not good
  • Ice Cream in the Freezer will start to get soft. That's really not that bad. lol
What can you do about this. Let me explain the defrost system in general so you get an understanding of what is going on.
The coils inside the freezer are the only part inside the whole refrigerator that "get cold". They need to stay free from excess frost build up so that air can pass through the coils and reach the refrigerator section of your refrigerator. Every eight hours or so, depending on the type of defrost timer or control you have, the compressor and fans will shut off and the machine will go into defrost mode.When the refrigerator is in defrost there is a heater that is tied into the evaporator coils inside the freezer that comes on. This heater is behind the rear panel inside the freezer where the evaporator coils are located. It melts the frost that has accumulated over the course of time. After about thirty minutes the machine comes out of defrost and goes back to normal operation.
Now the air can continue to pass through the coils and keep the freezer frozen and the refrigerator cool the defrost cycle is made up of 4 functioning parts the defrost timer, the defrost heater, the defrost thermostat and the fan .I will go through what each of these do
The Defrost timer Some refrigerators have a defrost timer. This type works like a clock. Every eight hours or so the machine hits the defrost spot and that's when defrost occurs Some refrigerators have an Adaptive Defrost Control. This is what makes a refrigerator energy efficient. It varys the length of time it takes the machine to go into defrost.So instead of energy hogging heater coming on every 8 hrs it could be different due to how many times you open the doors and how many times the compressor has run some models dont have a defrost timer and instead use a control board that works just like the timer it is usually located in the rear of the machine under a metal panel.
Defrost Thermostat
This is the component that controls how long the heater stays on when the machine is in defrost mode. Say the defrost cycle is thirty minutes, the heater may only be on for ten of those thirty minutes on the timer controls. On Adaptive Defrost Controls, when the heater shuts off, shortly after the machine exits defrost mode. Basically if the heater only stays on for ten minutes, the whole defrost cycle will only be about 12 or 13 minutes long.
Basically when the heater comes on, it starts to melt the frost on the evaporator. Once all the ice and frost is gone, the temperature behind the panel will start to rise. Once the temperature behind the panel rises to a certain temperature, the thermostat will break the current of electricity going to the heater. Bam, it shuts off and prevents your freezer from becoming a sauna, or an oven. I'm sure you get the drift. The heater is on the bottom of the evaporator coils and the defrost thermostat sits on top of the evaporator coils.
Defrost Heater
This one should be pretty simple. By now if you have read this far you should already know what this does and how important is it. Some defrost heaters are a coil of wire in a glass tube under the evaporator coils. Works like a light bulb basically. The other style looks like the bake element in your stove. They both get red hot either way and melt the frost.
The Fan
Some dont consider this to be part of the defrost cycle but if the fan is not working then the air is trapped inside the freezer and sometimes can cause the same ice up situation which is why I say to always look at the fan first
Continuity tests can be done to check the defrost thermostat and the defrost heater you can also do an ohms test between terminal 1 and 3 on your defrost timer which will tell if the motor section of the timer is good then you can check between terminals 1 and 4 to by doing a continiuity test which is to the compressor and tells the compressor how long to run if you turn the timer till you hear the click it goes into position to and you can do a continuity test on the heater between terminals 1 and 2 and then you can do a continuty test on these two terminals as well And here is the guide to how your defrost cycle works if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Feb 01, 2011 | Jenn-Air Refrigerators
REFRIDGERATOR SIDE DONT KEEP COLD, BUT THE FREEZER DOES? WHY?
This symptom can be caused by many different failures, defrost system failure,( defrost heater,timer,thermostat), something blocking air transfer path to the fresh food section such as: ice build up, damper door not operating, main thermostat, check all these or have tech come in and check.
Good luck !
Mar 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refridgerator is not staying cold. The
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Mar 06, 2010 | Refrigerators
Freezer works now and fridge still warm
your right the air is not getting through the cold coil / when you defroated it . did you remove the back of freezer . if not there is still 2 in of ice back there blocking the air flow/ now a good defrost is needed but you need to correct the problem of why this happened . either the timer / heater or defrost termminator is bad . usualy its the heater.. mm hope this helped .. feed back pls
Feb 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator: there is a annoying fan sound that will only stop when the freezer door is open. can you please help!
The fan stops when you open the door. The fan is behind the back cover inside the freezer. It's Probably iced up on the evaporator coils below the fan and on the fan. Probably a defrost problem.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Dec 08, 2009 | Dryers
2 year old Kenmore side by side refrigerator is too warm
the freezer feeds the refridgerator with cold air,when you open the freezer door,do you hear the fan blowing,if not you need to change the evap fan motor,next take out the second from bottom food bin and touch back wall,if you feel snow or ice you have a defrost problem, you'll have to take off back wall,advance the timer till it clicks into defrost and see if the heater comes on,if so you have a bad timer,if not read out the t-stat and the heater,if there are plug in wires on t-stat unplug them and bypass the t-stat by plugging t-stat wire to heater if heater comes on change t-stat,leave the heater on to help you defrost the ice off of evap coil and use hair dryer to melt ice,hope that helps
Nov 02, 2009 | Kenmore Refrigerators
GE Side by side Refridgerator (Artica) model PSC25MSTA. Freezer and refer side not cold. Noticed coil under ice maker hot. Did a test on ice maker per GE web site instructions, Tested OK. Noticed cold...
No,what it appears to be isthe evaporator is freezing over and hindering air flow. The water under the ice maker is actually condensation because the ice maker is colder than the cabinet temp. The unit should have an automatic defrost so it appears it is cycleling through yhe defrost. Unless you call out a tech to set the defrost timer, all you can do is unplug it and defrost in its own. Was the door ajar for any period of time? not completely closed? That will also do it because of humidity. The moisture in the air will freeze. The refrigerator side cools from bleed over from the freezer.
Oct 10, 2009 | Refrigerators
Freezer very cold, no air going into fridge it warm ANY SUGESTION
hi there,
check the blower fan inside evaporator,there is fuse on the back side of your refrigerator for cooling fan,check on this using multi tester if busted replace fuse.
Jul 06, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
