I have an amica washing machine,the red light has come on ???? whats wrong
5 Suggested Answers
  • 747 Answers
SOURCE: what is wrong if red
it could be sock or peace close jamed around bucket i would check around bucket see if thats the case unplug it for a few min. then plug it back in.
Posted on Feb 11, 2011
  • 6277 Answers
SOURCE: red service light is on
Unfortunately you do not say which particular make and model it is and different manufacturers use different codes for different problems!
So I am guessing but I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP ANY WATER!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Hope this is the problem and good luck!
John C
  • 6277 Answers
SOURCE: AMICA AWCT10L washing Machine Manual
Sorry but this forum does not supply any type of manual, installation instructions or schematic diagram direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 20, 2011
  • 6277 Answers
SOURCE: i have a amica AWCT
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 25, 2011
Where can I buy bobbins for an Amica sewing machine?
Search for:
Make Model bobbins
or
take a bobbin to a local sewing machine repair shop. If it's a common bobbin, they will recognize it and probably have some on hand.
Nov 09, 2017 | Sewing Machines
Where does soap powder go in amica AWB510LP
Top left hand draw pulls out, Right hand channel for washing powder
Jan 14, 2015 | Washing Machines
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Amica Mother board has been stopped working. its not spinning.
If the board is malfunctioning, your only source of action is to replace it.
May 24, 2012 | Washing Machines
Amica washing machine power stop whats the prolbem
Hi, my Amica AWCT washing machine has no power. I have checked the external source, together with the fuse in the plug that is all fine. Any suggestions would be appreciated! thanks Tam
Feb 02, 2012 | Washing Machines
Hi the red service light has come on and wont let me wash please tell me what is wrong with it thank you very much
the small cover trim across the bottom front of the washer comes off. under it is your pump clean out it is a cap you twist off to clean out the pump. have a towel ready water will come out, the red light is telling you to clean that part
Jul 13, 2011 | Whirlpool Washing Machines
What is wrong if red service light is on and washing machine wont start
Feb 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Indesit WIXXL146 washing machine will not turn on
sounds like interlock or pcb try lock first as this is cheap to replace regards jason
May 08, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
433 people viewed this question
Top Washing Machines Experts
