Question about Refrigerators
My kic fridge is not freezing whereas my freezer is overfreezing. Can you tell me what is wrong with it.How can I get it fixed.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Hi, I have a kic super kool fridge freezer. Everything in the fridge is freezing. Temp in the fridge is on 3. What can the problem be.
The refrigerator side has an independent thermostat and that can be damaged from a power surge, natural age, or defective internal components. If you can change it out yourself do it! If not; call the service center for assistance. Note: Failure to act could render the fridge usless and cause problems for the compressor down the road.
May 10, 2014 | Refrigerators
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
Hi I have a very old KIC fridge freezer the freezer is cold and works well the fridge is not icing up on the back board in the fridge everything going off in the fridge what could be causing this?
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Nov 01, 2011 | Refrigerators
KIC fridge not getting cold freezer ok , regassed 30 days ago
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Refrigerators
My freezer isnt working correctly ,isnt freezing the food and the fan only kicks in now and again and there is ice at the back of the freezer .can you help
It seems that the efficiency of the fridge has dropped as there is frost forming within the system due to a possible failure in the control circuit or the auto defrost timer.
It can also be related to a failure of the circulation fan or the thermostat.
Shut off fridge for about 6 hours and if it cools then the defrost timer must be checked along with the heaters.
Aug 02, 2011 | Beko TLDA662
Good day, I use a KIC 346l Fridge Freezer. Recently I have a problem with the freezer being over cooling. I did try and set the temperature lower but it is still over cooling. Please kindly assist....
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 17, 2011 | Refrigerators
Freezers too cold leaks h2o to fridge now fridge wont cool
because of too less gas in the system it cant make cool enough too switch off the compressor
May 10, 2009 | Refrigerators
Refrigerators Logo
637 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
