Question about Cobra 29 LTD CB Radio
Cannot get Led's to go on.Replaced with new one's and still the same thing..nothing...This is a Cobra 29 LTD.
    Guru:
  • 773 Answers
There is a break in the ribbon that goes from the board to the front assembly. Check the ribbons for disconnected wires, or breaks.
Posted on Sep 08, 2010
The calibrate needle wont move to the right to set whe trying to calibrate on cobra 29 ltd classic new radio
You have to press the transmit button to get the radio to send a signal that you can calibrate the SWR meter to. If you are pressing the transmit button and nothing is happening then it could be a blown final transistor, a bad switch, bad microphone connection etc.
Jul 05, 2014 | Cobra 29 LTD CB Radio
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
I have a Cobra 29 LTD the speaker no longer has sound. Can this be repaired?
if the speaker is blown, it can be replaced. If the mic is bad, or has a short, the radio will not go into receive mode. Then you will get no sound from the radio. Try a new mic.
Sep 25, 2010 | Cobra 29 LTD CB Radio
Cobra 29 ltd chrome quit transmiting still have pa and talk back changed driver and final still nothing any ideas
Have you check your voltage regulator. 2 outer legs should read 13 volts middle 9 volt. Around and about.
Nov 15, 2009 | Cobra 29 LTD CB Radio
Cobra 29 has bad connection
Sounds like the audio out put transistor is over heating. Could be from having it tuned to high. It will need to be changed.
Feb 18, 2009 | Cobra 29 LTD CB Radio
Cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Dec 23, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
Cobra 29 issues
Check D23 and D28. They are polarity protection diodes. It could also be the power knob.
Nov 09, 2008 | Cobra 29 LTD CB Radio
COBRA 29 LTD
Your concern is no transmit and no red transmit led -
If there is no receive likewise, then probably problem in the PLL/VCO section or 9V voltage regulator TR23 (2SC1096) or Zener diode D22 (9.1V).
If the receive is normal, then possibly any of two (2) faults:
1. microphone/PTT switch and/or the mic cable specifically the wire connected to pin# 3 of the connector; or
2. +8V switching transistor TR21 (2SA733P).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 30, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
