Question about Kenmore 62232 / 62234 / 62239 Bottom Freezer Refrigerator
Model# 596-63822200 Bottom Freezer Refrigerator. Makes loud noise around 15 seconds every 5 to 10 minutes. Temperature is warm in refregirator and freezer. Naomi
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 06, 2010
I have a Kenmore bottom freezer refrigerator. The freezer section is sometimes -10F and at other times is heating up to around 35F and things are melting. I hear a loud humming noise come on often now,...
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 13, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Fridge makes loud noise every ~10 minutesq
Does it have a ice machine it it? If yes, that means it is very normal mine does it thats what happens, if no... Then go get a new one, and bring it back. You may have a loose screw
Oct 08, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Freezer makes a humming noise and is not freezing
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My refrigerator is 2 years old never had any problem, now
if you have a warranty take it back, or call the manufacturer and have them take care of it
Feb 17, 2009 | Maytag MBF2256H Bottom Freezer...
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Amana Mod # ABB2223DEB Refrigerator
Try damper part number W10167268 from Whirlpool. They re-engineered the part, it's works different. Whirlpool issued a bulletin to servicers, but won't cover it under warranty (I have tried for many customers) "A bulletin is NOT a recall"
Jun 03, 2008 | Refrigerators
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Kenmore 62232 / 62234 / 62239 Bottom Freezer Refrigerator Logo
295 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
